Date/Time: Tue, 04 Nov 2025 10:40:28 +0000
If 390min can be used to get study data for Daily chart, how to I get same for Weekly.
View Count: 553
[2021-07-01 23:39:50]
The Stealthy Trader - Posts: 189
So, a study I use Bid Ask Volume Difference and in my spreadsheet I'm able to get all intraday results.
However the subgraph doesn't return any results for Daily period so I've successfully used 390min and it works.
With this logic I tried to use 390min X 5(1950min) to represent Weekly chart in minutes but that doesn't seem to work..
Any thoughts?
[2021-07-02 14:30:13]
John - SC Support - Posts: 42737
You should be using 1440 minutes for one day (24 x 60 = 1440), therefore for a 5 day week, it would be 7200 minutes (5 x 1440 = 7200).
[2021-07-06 16:34:26]
Refer to:
Chart Settings: Days-Minutes-Seconds-Milliseconds Per Bar (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings >> Bar Period Type)
