Date/Time: Wed, 16 Sep 2026 10:39:05 +0000
Can't connect to Gain Capital to verify my trading account.
View Count: 1285
| [2021-07-01 09:11:29] |
| anneb - Posts: 4 |
Hi, I upgraded my software to the latest SC version 2276 and have now not been unable to connect to the Gain data feed. So I signed up to the Denali data feed. Now at the start of the month my data is delayed and I can't connect to the Gain data feed to verify my account with them. What do I do? kind regards, annemarie message log: GAIN Capital/OEC | Connecting to trading server sim.gainfutures.com. Port: 9300. | 2021-07-01 02:03:24.693 GAIN Capital FIX Trading socket (1) | Creating socket. | 2021-07-01 02:03:24.743 GAIN Capital FIX Trading socket (1) | New receive buffer size: 5242880 | 2021-07-01 02:03:24.743 GAIN Capital FIX Trading socket (1) | Connecting to IP: 66.76.151.20. | 2021-07-01 02:03:24.743 GAIN Capital FIX Trading: Connected to FIX server. | 2021-07-01 02:03:24.854 GAIN Capital FIX Trading: Sending the Logon message. LocalCompID=Abertschi668. | 2021-07-01 02:03:25.053 GAIN Capital FIX Trading socket (1) | Socket gracefully closed by remote side. | 2021-07-01 02:03:25.163 GAIN Capital FIX Trading socket (1) | CloseSocket call. | 2021-07-01 02:03:25.163 GAIN Capital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2021-07-01 02:03:25.163 GAIN Capital FIX Trading socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-07-01 02:03:25.164 GAIN Capital FIX Trading socket (1) | Closed. | 2021-07-01 02:03:25.164 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-07-01 02:03:25.164 Select 'File >> Disconnect' to prevent further connection attempts. | 2021-07-01 02:03:25.164 GAIN Capital/OEC | Disconnected from the trading server. | 2021-07-01 02:03:25.164 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-07-01 02:03:25.178 GAIN Capital/OEC | Disconnected. | 2021-07-01 02:03:25.178 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-07-01 02:03:25.178 File >> Disconnect selected. | 2021-07-01 02:03:27.705 GAIN Capital FAST Data socket (0) | CloseSocket call. | 2021-07-01 02:03:27.705 GAIN Capital/OEC | Disconnected. | 2021-07-01 02:03:27.705 |
| [2021-07-01 15:00:13] |
| John - SC Support - Posts: 47903 |
There is no information in the log as to why the connection is not working. You will need to ask Gain Capital about this.
| [2021-07-01 19:16:57] |
| anneb - Posts: 4 |
Hi, thanks. The connection did just work fine with my original(very old 32bit) SC version. It was after the upgrade that it stopped working. I would just roll back to that older version, but I don't have access to that info as I am traveling in Europe, using my laptop. All my original data is on my desktop system in the States. I added the Denali datafeed 2-days ago as a possible work around, as I'm on the road and I don't have time to troubleshoot this problem. Could you possibly extend my real time data feed access through July, as I only had 2 days of real time data feed, so when I get back to the States I can figure out what is going on (or just go back to the previously working version). I would really appreciate your help. Thanks. |
| [2021-07-01 19:47:39] |
| Sierra_Chart Engineering - Posts: 24877 |
Definitely the issue is not due to the version you are running. Make sure the username and password for Gain Capital is properly entered in: Global Settings >> Data/Trade Service Settings And that the proper Server is set. The log above shows you are connecting to the simulation server and not the production server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-01 19:47:48
| [2021-07-02 10:40:50] |
| anneb - Posts: 4 |
Hi, thanks for your suggestions. Already tried all of these, including switching to their production servers. No luck! Well, it is really my fault - I should have tested this before I left. What if I canceled my new Denali subscription and then signed up again. This should give me to the end of July. Would that work? It's brute force - but at least it would get me up and running again. Sorry for taking your time, and thanks for your help. |
| [2021-07-02 14:16:33] |
| anneb - Posts: 4 |
Hi, found the problem. It's not my password, but my username that is off by a Capital letter. Sorry for bothering you with this and thanks for your support. |
