Date/Time: Tue, 04 Nov 2025 10:47:43 +0000
[Programming Help] - Volume Profile labels stuck on price axis on TPO Chart.
View Count: 644
[2021-07-01 04:47:57]
salvadorjr91 - Posts: 1
Hello Sierra Chart team,
I'm having a small issue, I don't know if it's by design, but I can't get the labels for the Volume Profile to show in the chart.
I have a TPO Chart with a Volume Profile next to it. I have the TPO Profile with Value Area Lines Extending until further intersection with labels, Right and Centered, and that is showing 100% correctly. The Volume Profile next to it that is based on the TPO Graph has the same exact settings. The lines are extending correctly, but the labels are not behaving as expected. They will not come out of the price axis on any alignment setting.
Let me know if there is something I missed, or if that's just how the software operates at the moment due to complexities.
I have attached a screenshot attempting to show what I'm describing:
http://www.sierrachart.com/image.php?Image=1625114255176.png
The assistance is much appreciated,
Thank you!
[2021-07-01 14:51:00]
John - SC Support - Posts: 42737
It is how the software is setup.
