Date/Time: Tue, 04 Nov 2025 10:39:30 +0000
Document GetReplayHasFinishedStatus()
View Count: 638
|   [2021-06-30 18:30:03]     |
| User660727 - Posts: 50 |
                There is currently no documentation for GetReplayHasFinishedStatus(), included the return value.  How is this different from IsReplayRunning()?
|   [2021-07-04 10:42:17]     |
                This is now documented here: ACSIL Interface Members - Functions: sc.GetReplayHasFinishedStatus() Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-07 16:20:00]     |
                When GetReplayHasFinishedStatus() returns 1, is the current bar the last bar of replay or was the previous bar the last bar?   How does this differ from simply waiting for IsReplayRunning() to return 0? My testing shows the following (version 2284): LastBar-2: IsReplayRunning=1,GetReplayHasFinishedStatus=0 LastBar-1: IsReplayRunning=0,GetReplayHasFinishedStatus=1 LastBar : IsReplayRunning=0,GetReplayHasFinishedStatus=0  |
|   [2021-07-08 00:53:29]     |
                If the replay has finished all the way to the end, it would have ended on the last tick of  the last bar. Otherwise, it would not be known where the replay ended. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-07-08 01:45:35]     |
                I opened another ticket reporting the bug: IsReplayRunning() incorrect on last bar Focusing on the documentation, it is unclear from the documentation (to me) what GetReplayHasFinishedStatus() returning 1 means. Does it mean the current bar is the last bar of replay or that the previous bar was the last bar? Date Time Of Last Edit: 2021-07-08 01:45:47
