Date/Time: Tue, 04 Nov 2025 10:49:37 +0000
AMP and Sierra Chart Question
View Count: 606
|   [2021-06-30 16:11:02]     |
| washingtonb - Posts: 5 |
                Hello, I have begun the process of acquiring an AMP trading account and have purchased the Sierra Chart Package 11. Can you help me determine the total cost involve with using your platform? So Far I have determined the following. Sierra Chart Service Package: $46 Full CME Group Exchange Fee : $3.25 TT FIX/CQG - Trade Routing : $0.10 Can you tell me if I have missed any thing? Will I also have to pay for the data feed from AMP?  |
|   [2021-06-30 19:31:01]     |
| John - SC Support - Posts: 42737 |
                The only item that is not correct is the "TT Fix/CQG - Trade Routing". Since you are using CQG with AMP, you will be paying those fees to AMP. You would need to check with them on the exact amount as well. Otherwise, the two fees you list are correct assuming that you activate that particular exchange. The exchange(s) you select will determine the exchange fees you need to pay. If you do not need the data from AMP for any other purpose (such as using a CQG trading platform, or Bookmap, then you would not need the data feed from CQG and you should let AMP know this. ---------------------------------- Note that your Denali Exchange Data Feed is not fully setup. You need to activate an exchange and ensure that everything is setup properly within your Sierra Chart software. Go through the remaining Setup Instructions starting here: Denali Exchange Data Feed: Activate the Exchanges: The CME Group (Denali Exchange Data Feed Setup Instructions) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
