Date/Time: Tue, 04 Nov 2025 10:51:00 +0000
Adding a new AMP account to my current setup
View Count: 1059
|   [2021-06-30 16:10:14]     |
| TriStar Trading - Posts: 184 |
                Evening folks - tomorrow I will be funding a new account with AMP. This one is in my personal name. It seems they do not like LLC's. Anyhow, I am using Denali/TT for the two other brokerage accounts I have assigned to this SC account. I will select Denali/TT when setting up live with AMP. I am only using one PC (8 monitors) so I'm hoping the two system CME limitation does not affect me. As with the other two accounts I plan to use the trade replication feature of SC to trade these multiple accounts. Is there anything extra I need to do for this setup to work except the account assignment form? Will the AMP account just get assigned to this account and is that it? Any other services or connections? Thanks, Mike
|   [2021-06-30 19:23:37]     |
| John - SC Support - Posts: 42737 |
                How many installations of Sierra Chart are you currently using and how many do you intend to use?
                 For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-30 19:40:35]     |
                I use one installation for swing trading charts usually after market. I do not trade from those charts. That is connected to SC Data - All Services [data]. The main installation is for day trading. I trade from these and use them daily. It is connected to SC/TT Futures Order Routing [trading. I suspect the swing trading installation may go away as I have been able to duplicate to a degree the simpler swing custom SC studies in ToS and I am looking at options. Also, I suspect the TriStar account with Dorman will become dormant or go away eventually as commissions and margins at AMP are much better. That being said I am currently using two installations as described above. I have only one PC. I was intending to assign the AMP account so I can replicate trades across brokerage accounts. I don't plan on any more installations or accounts.
|   [2021-06-30 20:26:29]     |
                You should be fine with your setup and not have to make any changes to your account settings.
|   [2021-06-30 22:16:55]     |
                Thanks! So when AMP says its ready to go do I fill out the "account assignment form"?
|   [2021-07-01 14:41:30]     |
                No, you are already setup with the Denali Exchange Data Feed, so you will just need to connect your Sierra Chart to the CQG account they give you. If there are multiple accounts within that, then those accounts will show up in Sierra Chart. Refer to the following for how to select a specific trading account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-01 16:43:17]     |
                Thanks John. I have a live trading chart setup for AMP/CQG using a second installation of SC so I know I am setup with AMP. I am connected using CQG WebAPI (trading). I was hoping to use the Order Allocation to Trade Accounts feature to trade multiple accounts. As of now the AMP account does not appear in the dropdown list of available accounts in my main installation of SC. I use the Denali/TT service so I thought I read that different clearing firms could be assigned to the same SC UserID. Is that possible in this case? Danka Schon! :)
                 Date Time Of Last Edit: 2021-07-01 16:45:11
|   [2021-07-01 18:35:06]     |
                It is possible to have different clearing firms both using the Sierra Chart Order Routing service to be assigned to the same SC User ID, which would allow you to trade both of them from the same Sierra Chart installation. But, since you have one instance where you are using the Sierra Chart Order Routing, and another with CQG, then those accounts are NOT available to each other. We apologize if this was missed in your statements previously, we thought you were referring to multiple AMP accounts for the Order Allocation to Trade Accounts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
