Date/Time: Tue, 04 Nov 2025 14:59:36 +0000
VA Lines do not work more than 1 day back - and VAH/L labels will not appear on right
View Count: 594
|   [2021-06-30 15:43:55]     |
| Dean Roberts - Posts: 79 |
                Hi All Two issues please; 1. When I create Volume Value Area Lines studies and select a period of days back, this works for the immediate prior day... but for days before that the lines do not line up with the prior day. This is for both full globex and only day session RTH. 2. When I create standard Volume By Price studies the name labels will only appear in the price column... and not on the 'right' when selected. I have to add Value Area Line studies to overlay and create the name labels. Can anyone help? Many thanks  |
|   [2021-06-30 19:20:58]     |
| John - SC Support - Posts: 42750 |
                1. We are not fully understanding what exactly you are seeing. Can you please give us an image of what you are seeing and let us know what the Input for the Reference n Periods Back is set to. 2. This is how the Volume by Price study was designed for those labels. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
