Date/Time: Tue, 04 Nov 2025 14:59:27 +0000
ZigZag SG2 Color based on Auto-Coloring (Based on +/-) number
View Count: 610
[2021-06-30 12:30:23]
Sudhirc - Posts: 57
In Zig Zag study when i select to display the delta numbers (selected In 1: Ask Bid Volume Difference), Auto Coloring not working.
i.e - On Down swing if the delta is positive would like to see green (or color of our choice as selected)
- the same way, for Up swing if delta is negative, number would like to see Red (color of our choice)
Can this be done? Please review attached pic for clarification.
Thank you,
Sudhir
http://www.sierrachart.com/image.php?Image=1625056163568.png
imageCapture.JPG / V - Attached On 2021-06-30 12:20:56 UTC - Size: 105.04 KB - 199 views
[2021-06-30 14:10:43]
John - SC Support - Posts: 42750
What you are asking for would be a Feature Request, as right now it is using the coloring based on whether it is an Up Swing or a Down Swing. We have set this post to be a "Feature Request".
