Date/Time: Tue, 04 Nov 2025 10:49:38 +0000
converting very old version of sierra charts (v. 626)
View Count: 612
[2021-06-30 11:50:47]
ej-kwes - Posts: 1
Hi. Probably haven't received a question like this before.
After a very long break of using Sierra Charts (about 11 years), I recently downloaded the latest version (2282). I tried loading a cht file from the old version (626) and received the following error in the message log: "Encountered invalid field code (123) while reading Chartbook file C:\..." I would like to be able to access those old chart settings/files, is there a way of upgrading the files, or is the version just too old?
Thanks!
Elliot
[2021-07-01 01:18:08]
In newer versions of Sierra Chart there is not support for opening a Chartbook from a version that far back.
You will need to create new charts.:
Chartbooks (Workspaces)
Date Time Of Last Edit: 2021-07-01 21:32:27
