Date/Time: Tue, 04 Nov 2025 14:59:30 +0000
Setting up live stock data
View Count: 609
|   [2021-06-30 09:24:32]     |
| Slick - Posts: 1 |
                I'm still still confused.  I have an account with TDA but it looks like this broker is not supported on getting discounted live data.  I'm using Sierra Charts for the footprint chart function.  If I do not subscribe to any additional data will I be able to view historic footprint charts on US stocks?  If so, how long is the data delayed?  Alternatively, what is the best paid option to get live data? Ballin on a budget.  Thanks.
|   [2021-06-30 10:07:17]     |
                You will want to use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service The data is delayed 15 minutes, and updates every 20 minutes. This will be the least expensive option. And then we are also coming out with a new NASDAQ data feed soon. For real-time data, for now you need to use this data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-30 10:07:56
