Date/Time: Tue, 04 Nov 2025 14:57:38 +0000
Moving DOM order column
View Count: 675
[2021-06-29 19:39:31]
User425645 - Posts: 123
Hello, how do I move the DOM column that is used for moving order/cancelling orders in the DOM?
imageCapture.PNG / V - Attached On 2021-06-29 19:39:11 UTC - Size: 39.39 KB - 249 views
[2021-06-29 19:57:24]
John - SC Support - Posts: 42750
What you have circled in the image is your position order line. That particular item can be moved by the two settings starting here:
Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu)
