Date/Time: Thu, 10 Sep 2026 00:54:53 +0000
Rithmic Direct-DTC Issue: Chart is not updating
View Count: 2022
| [2021-06-28 23:06:44] |
| SabikiSensei - Posts: 76 |
Chart is not updating or downloading correctly. I'm currently connected through Rithmic Paper Trading - Chicago Area - Aggregated. When I load up the chart NQU1-CME, it will give me two errors: 1) Symbol is unknown. Click for symbol information. Exchange not specified. 2) Download failed. Error downloading historical intraday data for NQU1-CME. Exchange not specified. Then I refer to the documentation and see that okay.. maybe the symbol is in the wrong format. I click File -> Find symbol and click on NQU1.CME. This should fix the problem but then I get this error: Download Failed. Error downloaded historical intraday data for NQU1.CME. no data. This problem DOES NOT happen when I am connected through the old Rithmic Trading w/ the Rithmic DTC bridge. The symbol format is in the old NQU1-CME and the chart loads completely fine. Date Time Of Last Edit: 2021-06-28 23:07:31
| [2021-06-29 15:40:05] |
| John - SC Support - Posts: 47822 |
You need to check with your broker and Rithmic to see if you are setup to be able to use the new interface. We are not sure if Rithmic may still be limiting its use.
| [2021-06-29 21:25:03] |
| Sierra_Chart Engineering - Posts: 24817 |
Yes you do need to use the new symbol format as listed in File >> Find Symbol. We do not think anything special has to be done on the Rithmic system for your account to support the new interface. Your existing Rithmic account should be fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-07-01 15:39:46] |
Please refer to this short YT clip I made to show you the problem even after I followed your steps. https://www.youtube.com/watch?v=B4QbxDwbYWY&ab_channel=JonathanVo I believe it is a symbol mapping issue. The chart will only load when the symbol has a '-' and not a '.' |
| [2021-07-03 03:51:22] |
Is this an issue that I will have to take up with Rithmic or is it an issue related to SC? I'm wondering if other users are experiencing the same problem or its just me. It was working for 1 day when I tried it last week but after that I encountered this issue. Would you like me to paste the message log for the error? Date Time Of Last Edit: 2021-07-03 03:51:44
| [2021-07-07 08:40:53] |
We apologize for the delay. We want you to use the new Rithmic connection explained here: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-07-07 11:16:35] |
| Tecomed - Posts: 6 |
Same problem. No historical data
| [2021-07-08 08:50:03] |
We cannot help with Rithmic data. For data for Sierra Chart use the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-08 08:50:16
| [2021-07-08 16:48:41] |
Thank you. It works now. I had to switch my service package to 10 because I was previously on 5.
