Date/Time: Tue, 04 Nov 2025 14:59:34 +0000
M and W indicator?
View Count: 867
[2021-06-28 22:21:17]
Chadly - Posts: 65
Have you guys ever had a request for an "M" and "W" indicator? Would be much like your candle stick patterns I suppose except is a pattern on a chart and not just a couple candles. These M and W are popular for fake outs/break outs.
Thanks again for all your work!
Chadly
[2021-06-29 13:21:57]
John - SC Support - Posts: 42750
Take a look through the Candlestick Pattern Finder to see if there is anything that is close to what you are looking for. It does not look, offhand, like we have those specific ones.
CandleStick Patterns Finder: Available Patterns
[2021-06-29 17:38:17]
Chadly - Posts: 65
Thank you! yes, I do love your candle stick pattern finder, great work.
However, there is not something like the M and W in there. The M and W may also have variations so this may get complicated. I have attached an example.
This thing is huge. If you'd like to privately contact me it may be a good idea as this is only a piece of a huge working idea. cje83@msn.com
This may want to be turned into a private discussion.
imagem and w examples.jpg / V - Attached On 2021-06-29 17:37:15 UTC - Size: 79.96 KB - 365 views
[2021-06-29 17:50:55]
We do not have the time right now to put into developing these patterns. We are just busy with a lot of different things.
The source code for the Candlestick Pattern Finder is available in Studies4.cpp which is in the ACS_Source folder under your main Sierra Chart folder. You can either modify the existing code or create your own study to perform what you are looking for. Refer to the information on the ACSIL interface here:
Advanced Custom Study Interface and Language (ACSIL)
