Date/Time: Tue, 04 Nov 2025 12:43:34 +0000
Copying toolbar from one Chartbook to another
View Count: 618
|   [2021-06-27 21:36:38]     |
| countryboy92 - Posts: 101 |
                I set up my toolbar in one chartbook, and then was notified that I had to update to a newer version of Sierra Charts. My toolbars are now back to the default. Is there a way to copy toolbar settings from my old Chartbook?
|   [2021-06-27 22:08:49]     |
                Do you know what version you updated from? The Control Bars are contained within the Sierra4.config file and there are backups of this file . You may have come from a significantly older version, in which case they are stored in Sierra3.CFG Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
