Date/Time: Tue, 04 Nov 2025 12:43:36 +0000
SCDateTime Problem
View Count: 732
|   [2021-06-27 19:35:20]     |
| User39772 - Posts: 311 |
                Hello, I have the following code: SCDateTime DateTime = sc.LatestDateTimeForLastBar; SCDateTime PosTime = PositionData.LastEntryDateTime; //5 Minutes after open of the position I want an action to occur //but the following code does not work, argument "DateTime == PosTime.AddMinutes(5)" never becomes "true" if ( DateTime == PosTime.AddMinutes(5) ) Subgraph_Test[sc.Index] = sc.Low[sc.Index]; //Is my understanding wrong ?  |
|   [2021-06-27 22:20:25]     |
                Change this to as shown: if ( DateTime >= PosTime.AddMinutes(5) )
But you need to carefully consider how this would work. You really need to check a range of time like across one minute, to ensure you get a match. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-27 22:21:10
