Date/Time: Tue, 04 Nov 2025 12:43:34 +0000
Clock-RealTime Study drives GPU utilization from
View Count: 658
|   [2021-06-26 22:19:59]     |
| User656492 - Posts: 157 |
                I will not be using this study until it's fixed.  I recommend others follow suit.
|   [2021-06-26 23:18:18]     |
| Sierra_Chart Engineering - Posts: 21299 |
                There  is not a problem with this study at all. You need to increase the  Chart Update Interval.  Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.5 - Chart Update Interval (30.5) You may have changed it to be very low or the chart is very complex with its graphics. So all of this is up to you to resolve. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-26 23:18:54
|   [2021-06-27 03:53:36]     |
                Changing the update interval did indeed address the GPU utilization, however, this is obviously a design issue. The connection between a display of the time and the chart update interval is hardly intuitive. Nevertheless, thanks for the prompt response.  |
