Date/Time: Tue, 04 Nov 2025 10:51:00 +0000
Enable or disable timeframe moving through different Charts
View Count: 785
|   [2021-06-26 14:43:07]     |
| User230940 - Posts: 121 |
                Hello, I have several different Charts of the same Underlying (VolumeProfile, Footprint, Candle) with different Timeframes. For example: If I have the focus on a VolumeProfile and move to the different times the FootPrint 1 minute Chart will be moving in same direction as the Mouse on VolumeProfile Chart. This is a very nice feature for Analyse. But is it possible to disable and enable this feature for a Chart? I am using "hand" . Thanks regards  |
|   [2021-06-27 22:22:40]     |
                If you only want to enable the Hand tool for individual charts, yes that can be done. You will need to set Global Settings >> Tool Settings >> Use Common Drawing Tool for Charts to No. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-06-28 08:17:11]     |
                Hi, thanks but this is not what I am searching for. I problem I have is, In case I have the focus for example on a Daily Chart and I move over the different daily Candles. Than the visible chart on my 1 Minute FootPrint will follow the daily Chart/Candles on the other Screen. This is still active with the configuration above. Thanks  |
|   [2021-06-28 14:28:48]     |
| John - SC Support - Posts: 42737 |
                We think what you are looking for is the Synchronize Chart option. Refer to the following: https://www.sierrachart.com/index.php?page=doc/Tools.html#SynchronizeCharts For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-30 09:53:47]     |
                Hi John, perfect. Thanks. That`s it. And easy to activate. By the way it it possible to sync drawing between linked Charts? I dray in one Chart and this will be sync to the Linked Chart? thanks best regards  |
|   [2021-06-30 13:37:33]     |
                You need to copy the drawings for what you are wanting. Refer to the following: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-07-01 08:53:13]     |
