Date/Time: Tue, 04 Nov 2025 12:43:35 +0000
User Defined Setting on an intraday chart
View Count: 640
[2021-06-25 16:20:00]
User180814 - Posts: 45
Hello Sierra,
I am trying to use an intraday chart with User Defined settings as constant range settings allow the chart to move as price moves. User Defined does not. The issue is I can not scale out the chart so that it is big enough to see the bars. Is there a way to use User defined settings and scale out the chart or zoom out the chart to make it bigger. I tried with the various ways on the right margin such at Interactive scale etc. Thank your for your response.
[2021-06-25 16:49:18]
John - SC Support - Posts: 42737
You can definitely adjust the Vertical scale while it is set to Constant Range (unless you are in a Logarithmic scale). As you mentioned, you would want the scale to be in Interactive Scale Range mode and then just right-click on the price ladder and move it up or down to expand or contract the scale. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
[2021-06-25 17:01:34]
Is there a way to keep the chart from moving when using Constant Range Scale?
[2021-06-25 18:31:32]
You would need to use User Defined to not have the chart move with the bars. Refer to the following:
Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range
