Date/Time: Tue, 04 Nov 2025 12:43:33 +0000
Weird mouse/cursor behavior
View Count: 876
[2021-06-25 15:45:11]
Tonkadad - Posts: 235
With SC on 2 monitors, if I select a drawn object to move or adjust on monitor 2, the cursor immediately jumps approx 12" to the left of the initial position.
Similar thing happens when on monitor 1, select drawn object (say a line) the cursor jumps to the right approx 12", from initial position.
Any thoughts?
[2021-06-25 16:40:14]
John - SC Support - Posts: 42737
Most likely it is a mouse or operating system issue (be sure to check your mouse battery as well). But, the one thought we want to check on (although it should not do what you are stating) is whether you have the Synchronize Charts option enabled and are these charts part of the same Chartbook?
Refer to the following information:
https://www.sierrachart.com/index.php?page=doc/Tools.html#SynchronizeCharts
