Date/Time: Tue, 04 Nov 2025 12:43:36 +0000
volume profile
View Count: 602
|   [2021-06-25 10:32:43]     |
| Farid Zantout - Posts: 3 |
                Hello I'm using IB for data, the volume on ES on my volume profile is different from the data in IB. Can you tell me why? Farid Zantout  |
|                  Attachment Deleted.  |
|   [2021-06-25 15:00:54]     |
| John - SC Support - Posts: 42737 |
                We would need to know what exactly that Volume of 80.1k is. Offhand, it looks like it is the volume from the previous day, just based on the other numbers near it (assuming those were high and low of the previous day). In which case, you are looking at the wrong information in your chart, as you are looking at the current day that started in the evening of June 24.
                 For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-25 17:41:13]     |
                that was a live screen shot of the ES contract volume today, to show you the difference between what was showing on the volume profile in SC..
|   [2021-06-25 18:37:39]     |
                The most probable reason for a difference is that your Session Times are not covering the exact same time for which the IB volume is calculated. In general you would have to make sure that everything is matching up in order to make the comparison.
