Date/Time: Tue, 04 Nov 2025 14:59:31 +0000
[User Discussion] - study/price overlay
View Count: 965
[2021-06-24 11:21:32]
User425645 - Posts: 123
Hello, I need some help with the study/price overlay study. I'm trying to achieve a singe chart with 4 different lines of cumulative delta with varying volume inputs - the image below of the clean single chart is what I'm aiming for, and the image of the 4 bad looking charts is my work in progress. Ok, as for the specific questions: how do I get the labels on the y-axis? how do I make each chart start at the 0 value like in the image below as well? and how do I make the chart into lines instead of candlesticks like the chart image below?
thanks for your time, it's really appreciated.
imageCapture.PNG / V - Attached On 2021-06-24 11:09:35 UTC - Size: 172.1 KB - 251 views
imageCapture.PNG / V - Attached On 2021-06-24 11:10:00 UTC - Size: 102.7 KB - 232 views
[2021-06-24 12:55:06]
User310645 - Posts: 49
On the original charts not the overlay study...
Check the subgraph name label and reverse colours boxes. Set horizontal align to right.
Change the study settings to reset on session start.
Just plot the close subgraph instead of ohlc (ie. set the other to ignore)
[2021-06-24 17:17:49]
Awesome thanks. in regard to the last part about potting the close subgraph: when I keep "close" visible and change the "open", "high", "low" to ignore and hit "apply" the screen flashes and changes all the options back to visible. I've tried on both the overlay study and the original charts - same thing. please let me know how to deal with this.
imageCapture.PNG / V - Attached On 2021-06-24 17:14:29 UTC - Size: 166.87 KB - 214 views
[2021-06-24 17:23:44]
Sorry, yes, the graph draw type should be line on close in the original chart.
[2021-06-24 17:41:52]
eh. still not working
imageCapture.PNG / V - Attached On 2021-06-24 17:41:39 UTC - Size: 163.29 KB - 210 views
[2021-06-24 17:47:44]
On the study, not on the chart settings
imageCapture.PNG / V - Attached On 2021-06-24 17:47:30 UTC - Size: 11.58 KB - 224 views
