Date/Time: Tue, 04 Nov 2025 14:58:02 +0000
Consistent Time Scale/Horizontal Value Intervals
View Count: 744
|   [2021-06-23 18:08:00]     |
| jonnyot - Posts: 6 |
                It's odd to me, but I'm unable to find a solution of how to set consistent time scale/horizontal value intervals.  I'd like my five minute chart to have consistent 5 min time scale values listed below the chart.  Also on my separate 1 min chart- to have 1 min scale value intervals, etc.   Currently, my 5 min chart intervals read: 3:20, 5:10, 5:45, 8:20, 8:45, 12:15 etc. I also would like the "Gap Fill- fill all bar gaps" Increasing the bar spacing does not appear to remedy this problem. Please assist- thank you!  |
|   [2021-06-23 19:03:05]     |
| John - SC Support - Posts: 42750 |
                There really is not a way to get exact increments for the horizontal scale. You would just have to adjust the spacing to get as close as you can to what you want. The system automatically chooses the numbers based on what can fit for the scaling at that moment. With regards to the bar gap, refer to the following: Chart Settings: Gap Fill (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings) But we think you may also be referring to missing bars where there is no data. For this, refer to the following (and the one after it): Chart Settings: Include Columns With No Data (Chart >> Chart Settings >> Bar Period >> Chart Bar Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
