Date/Time: Tue, 04 Nov 2025 14:59:32 +0000
Chart not updating
View Count: 683
[2021-06-23 18:03:54]
GuerrillaM - Posts: 18
Hello, I am trying to look up ticker symbol TTD but it is not updating. It recently had a split and now the price is stuck at $590. How can this be fixed? Thank you.
[2021-06-23 22:04:09]
Sierra_Chart Engineering - Posts: 21301
We are seeing real-time data for that symbol.
Reconnect to the data feed:
[2021-06-23 23:59:59]
Thank you I sent the Message log for analysis.
[2021-06-24 14:17:42]
John - SC Support - Posts: 42750
We are not seeing any issues in the log. Go to the chart for TTD and select Edit >> Delete all Data and Download. Let us know what happens after that.
[2021-06-24 14:25:10]
It updated the chart but still has the same issue.
[2021-06-24 14:49:40]
When we look at the data we see the split on 6/17 and the current price is around $73 - $74 right now. For instance, here is where we see the split:
http://www.sierrachart.com/image.php?Image=162454610971.png
Can you please give us a screenshot of what you are seeing by following these instructions:
Also, how are you selecting the data to display under Chart >> Chart Settings? Are you using a Date Range by any chance?
[2021-06-24 15:02:18]
Thank you, I reset the platform and tried the previous steps. It seemed to work!
