Date/Time: Tue, 04 Nov 2025 14:58:03 +0000
Unwanted Sound Alerts
View Count: 521
|   [2021-06-23 13:56:49]     |
| User993067 - Posts: 190 |
                Been using software 3 years...today every order placement or stop/exit order adjustment is accompanied by audio response...opening and closing of positions also...SC never did this before ...I did not unknowingly adjust that I can see...mute all alerts sounds not working.  Please help...latest version.
|   [2021-06-23 15:00:12]     |
| John - SC Support - Posts: 42750 |
                There has not bee any change that should have caused this. The thing to check is that the options for playing an Alert when an order is placed or moved are set the way you want them. Refer to the information starting at the following and the 4 entries below: Global Trade Settings Windows: Play Alert For New Order (Global Settings >> General Trade Settings >> Notifications) For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
