Date/Time: Tue, 04 Nov 2025 14:59:32 +0000
Do not receive CME delayed intraday data
View Count: 568
|   [2021-06-23 13:36:18]     |
| User805816 - Posts: 6 |
                Hello, I dont receive CME delayed intraday data. But I do receive EUREX delayed intraday data + CME historical data. Could you pls help with that? Thanks, alexander  |
|   [2021-06-23 14:49:58]     |
| John - SC Support - Posts: 42750 |
                Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-24 12:07:35]     |
                for some strange reason it works now after i cleared message log. thanks for your support.
