Date/Time: Tue, 04 Nov 2025 14:58:07 +0000
[User Discussion] - Point & Figure Chart
View Count: 1054
|   [2021-06-23 01:44:02]     |
| 58LesPaul - Posts: 429 |
                Has anyone had any luck creating a P&F chart that projects a move accurately? I've tried the P&F bar type and the P&F study and all box sizes and can't get anything to accurately project a move consistently. IDK what I'm doing wrong. Thanks  |
|   [2021-06-23 16:17:24]     |
| User90125 - Posts: 715 |
                Show your work then.  What exactly does your chart look like? And what does a proper PnF chart look like to you?  |
|   [2021-06-23 21:44:54]     |
                Here's my 40 tick(10 point) x 1 P&F chart. When I measure across at the last point of supply I get 15 boxes x 10 points is 150 points. 4145 + 150 = 4295 and of course it only reaches 4260ish. I have tried 1x1, 4x1, 8x1, 12x1, 16 and 20x1, and nothing works well consistently. I'll have one that comes close but look at others and they don't come close. I would like for the measurements from last point of supply to project the distance of the move, at least come within 5 points. I am trying to follow Wyckoff and use his P&F chart style for projection of move. Date Time Of Last Edit: 2021-06-23 21:47:26
|   [2021-06-24 13:54:52]     |
                Something else I’ve noticed, if the above chart is a 10 point(40 ticks) P&F, why is the price scaling show 5 points for each box size?
