Date/Time: Tue, 04 Nov 2025 14:58:06 +0000
live data for us equities
View Count: 570
|   [2021-06-22 22:27:29]     |
| User696148 - Posts: 1 |
                hello, i have currently 3 service packages activated: 36.00 Sierra Chart Usage Time at Service Package 5 - Advanced. 25.00 Exchange Data Feed: 250 Real-Time Symbols (1st Connection). 10.50 Activated Exchange: U.S. Equities (NYSE, NASDAQ, AMEX) It works awesome, but I am questioning if I really need all the 3 packages for the live data feed for us equities. Or if there is a cheaper way around. Thanks for your help. regards, Nova  |
|   [2021-06-23 13:37:30]     |
| John - SC Support - Posts: 42750 |
                What you have selected are the correct options in order to get the U.S. Equities data.  The only item you could potentially change would be to go from Package 5 (Advanced) to Package 3 (Standard), but only if you do not use the Advanced features such as Numbers Bars and TPO graphs. Refer to the differences in the packages here: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
