Date/Time: Tue, 04 Nov 2025 14:59:37 +0000
CME E-mini real-time market profile data
View Count: 577
|   [2021-06-22 16:19:29]     |
| 1M2021 - Posts: 1 |
                Hello, I'm new to Sierra Chart. I need to gain real-time data access to the CME E-mini futures (ticker: /ES) market profile data. However, I use ThinkorSwim, which is not compatible with Sierra. Please let me know what I need to do to get real time data. I'm a non-professional. Thanks, Antonio Gomez  |
|   [2021-06-22 17:02:05]     |
| John - SC Support - Posts: 42750 |
                You are correct, ThinkOrSwim is not supported by us, so you can not use that to validate your status of having a trading account in order to qualify for the non-professional CME exchange fees. We really would recommend the solution described in the following link, which only requires $100 to have an account that can be verified. You will save the money over the course of a year. Easy Solution to CME Funded Trading Account Requirement The only other option would be to pay the professional fees. Whatever you decide, when you are ready, you will follow these instructions to get setup with the Denali data for the CME group: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
