Date/Time: Tue, 04 Nov 2025 14:59:29 +0000
Move subgraph draw styles up/down
View Count: 696
|   [2021-06-21 17:20:58]     |
| User202883 - Posts: 24 |
                I'd like to shift draw styles up and down so I can display multiple signals on the same bar without overlapping. For example, moving points, triangles, diamonds, etc, up or down 10 ticks. Is this possible?
|   [2021-06-21 18:56:41]     |
| John - SC Support - Posts: 42750 |
                It depends on the study you are using as to whether it has the option built in or not. The Color Bar Based on Alert Condition, for instance, has the option in the Inputs called Draw Style Percentage/Ticks Offset. Refer to the following: Color Bar Based on Alert Condition: Draw Style Percentage/Ticks Offset For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
