Date/Time: Tue, 04 Nov 2025 14:58:05 +0000
Bug with CBOE Europe Daily since June the 7th (no data except current bar)
View Count: 557
[2021-06-21 07:42:07]
User393368 - Posts: 12
There is a critical bug with CBOE Europe Daily since June the 7th (no data except current bar in Historical charts).
Please see screenshot attached for the symbol "MRN.P.DX", but it's the same for all the Symbols in Historical charts only.
- If I uses "Delete and download data" I get the same thing.
- During the day, the current bar is fine, and at bar close it becomes flat
Can you let me know if there is anything I can do to fix this ?
Regards,
imageCapture-bug-daily.PNG / V - Attached On 2021-06-21 07:41:47 UTC - Size: 21.77 KB - 201 views
[2021-06-21 18:18:06]
Sierra_Chart Engineering - Posts: 21301
We are checking with our data provider about this.
There are two different ways this can be resolved.
[2021-06-23 08:20:08]
Any news about this ?
You said there are 2 different ways, is there one I can implement now ?
Thank you for your help,
Regards,
[2021-06-23 10:12:56]
According to our data provider this should now be resolved.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
