Date/Time: Tue, 04 Nov 2025 16:32:19 +0000
Copy and Move Drawings from one chart to another permanently
View Count: 985
| [2021-06-20 23:18:06] |
| User629461 - Posts: 193 |
Hi, is there a way to copy and move Drawings from one chart to another permanently? I have 2 charts open in the same workbook (one is continuous and the other is not). I want to move drawings from the non-contionuous to the continuous chart and then delete the non-continuous chart. I understand drawings can be copied from another chart in Chart Settings > Adavnced Settings, but this still requires the chart to be active. If I delete the chart, the drawinmgs also disappear. Thanks.
| [2021-06-20 23:43:47] |
No this is not supported. Alternatively what you can do is just duplicate the chart, that has the Chart Drawings and make changes to its Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-20 23:44:33
