Date/Time: Tue, 04 Nov 2025 16:32:26 +0000
Daily OHLC study
View Count: 787
| [2021-06-20 22:44:49] |
| User447431 - Posts: 29 |
Im using this study with settings "reference days back: 1" and "number days to calculate: 1"..... I think it should display only current day's highs and lows, however after the NY session when the day closes, this study starts to show the new day highs and lows and the previous day high and low aswell... so I always have to reload the chart to make the study works properly (showing only the current day high and low).. how can i fix this study? dont want to keep reloadin lots of charts every day.. picture attached |
| [2021-06-20 23:46:34] |
Yes that is normal behavior. You would need to Reload the chart (Chart >> Reload and Recalculate). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-21 01:49:06] |
| 58LesPaul - Posts: 429 |
I never had to do that before, why is it considered normal behavior now? Is that a change you made in the latest version? Thanks |
