Date/Time: Tue, 04 Nov 2025 14:58:14 +0000
Breakdown of Pricing
View Count: 701
|   [2021-06-20 21:07:46]     |
| myke - Posts: 23 |
                Hello, Currently using my SC Trial and I just wanted to make sure I understand the price components. I'll be needing Package 12, Denali Feed, and CME With Market Depth (Non-Professional). With the 20% discount, is this what I can expect to pay: - Package 12 w/ Denali @ $44.80 - CME @ 10.40 = comes out to $55.20 PER MONTH. Is this correct? Another question - I have an Interactive Brokers account, but I want to use SC Denali feed and NOT Interactive Brokers' data. Do I only need to connect to Interactive Brokers once a month to continue using the Denali data? Thanks a lot. Date Time Of Last Edit: 2021-06-20 21:11:48
|   [2021-06-20 22:30:47]     |
                 = comes out to $55.20 PER MONTH. Is this correct?  Yes this is correct.Do you require Market by Order data?  Do I only need to connect to Interactive Brokers once a month to continue using the Denali data?  Yes.
                Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-20 22:31:06
|   [2021-06-22 14:32:59]     |
| myke - Posts: 23 |
That's the Market Depth / DOM, I'm assuming. Yes I'll be needing that. Date Time Of Last Edit: 2021-06-22 14:33:12
|   [2021-06-22 15:47:39]     |
| John - SC Support - Posts: 42750 |
                You have the Market Depth as part of the selections that you provided initially. The question is about Market by Order data, which shows you the individual limit orders at each price, not just the aggregate you get with the Market Depth. Refer to the following for more information: Market By Order Data If you do require the Market by Order data, then you will need Package 12. You will find the Setup Instructions on the page linked above that go through what you need to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-23 13:36:25]     |
| myke - Posts: 23 |
                Okay, so my understanding is: - Market Depth refers to Time + Sales - Market by Order refers to DOM Is this right? Thanks Date Time Of Last Edit: 2021-06-23 13:36:41
|   [2021-06-23 14:57:47]     |
                Not quite. The Market by Order and Market Depth are both referring to the same information, which are the limit orders at each price level waiting for the price to move to their level. The Market Depth is just a single number that shows the total quantity of those limit orders waiting. The Market by Order breaks down the total Market Depth and gives you insight into the individual orders that make up that composite including the queuing order of the orders as well. The only caveat with the Market by Order is that we do not show every order including the single valued ones. Right now, you are limited to displaying down to an order size of 4. Both sets of values can be displayed in the DOM. For the most reliable, advanced, and zero cost futures order routing, use the Teton service:  Sierra Chart Teton Futures Order Routing  |
|   [2021-06-24 02:07:57]     |
| myke - Posts: 23 |
                Appreciate the explanation. I don't need MBO, so it looks like Package 11 is perfect for me. One last question: on the DOM, I would like to see the the Ask/Bid Market Depth Pulling/Stacking columns. Will I require Market Depth data for this (CME with Market Depth for Non-Professionals)? Date Time Of Last Edit: 2021-06-24 02:14:25
|   [2021-06-24 04:35:05]     |
                Yes is service package 11 is fine and you will require market depth data for pulling and stacking calculations.
                 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
