Date/Time: Tue, 04 Nov 2025 16:32:26 +0000
Older Releases of Sierra Chart
View Count: 737
[2021-06-19 04:11:54]
toews&kane - Posts: 209
Hi there, when I try to download a specific version for example it says incorrect URL when getting common files list to download, thanks for your help.
[2021-06-19 04:18:07]
And also what is the newest release I can install for now to support rithmic. Reason I ask is I signed up for convergent and the study needs 2217 or higher, I hope I can go that high with rithmic. I've been meaning to switch to a different feed just didn not get around to it. I can't just turn my charts offline, but I will switch asap.
Can you provide one that would work with sierra and bookmap? need to rely on your expertise here.
[2021-06-20 00:36:48]
Sierra_Chart Engineering - Posts: 21306
In this case, the version is no longer available:
You can use the latest version with Rithmic. Updated instructions:
