Date/Time: Tue, 04 Nov 2025 16:32:27 +0000
Different Volumes shown on TPO Chart
View Count: 715
[2021-06-18 18:34:05]
UserPart - Posts: 9
When I use the same charts in 2 different laptops, Volume values are different. I am using TPO charts for ES ,and the volume by price is different in 2 different laptop. Please help is resolving the issue. I have manually checked all the settings and its same but not sure whats causing the issue. Volume is like couple of hundreds more for each price.
imageVolume1.PNG / V - Attached On 2021-06-18 18:33:04 UTC - Size: 43.43 KB - 191 views
imageVolume2.PNG / V - Attached On 2021-06-18 18:33:12 UTC - Size: 50.75 KB - 191 views
imageVolume3.PNG / V - Attached On 2021-06-18 18:33:18 UTC - Size: 42.22 KB - 200 views
[2021-06-18 20:25:48]
John - SC Support - Posts: 42755
There is no way for us to know where the difference is coming from. You have to make sure that everything is the same between the two systems in terms of the chart setup, study setup, and data feed.
