Date/Time: Tue, 04 Nov 2025 14:58:06 +0000
Incorrect historical data for GCQ21 on 2021-06-14
View Count: 946
|   [2021-06-18 17:07:07]     |
| User218244 - Posts: 21 |
                The daily historical High price for GCQ21 on Mon 2021-06-14 with the Sierra Chart datafeed is 1906.2, erroneously copied from the previous day, but should be 1879.7.
|   [2021-06-20 02:53:33]     |
                We will let our data provider know about this. Whenever you see issues like this with the historical daily futures data you can also just contact Barchart here: Https://www.Barchart.com Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-20 02:53:51
|   [2021-06-21 18:22:34]     |
| Sierra_Chart Engineering - Posts: 21301 |
                We did report this to Barchart and they said the value is correct and according to what the exchange is providing so there is not any   incorrect price. First, before making a report like this, check the value with the exchange first: https://www.cmegroup.com/trading/metals/precious/gold_quotes_settlements_futures.html#tradeDate=06%2F14%2F2021 Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-06-22 13:27:16]     |
                I investigated this further. It turns out there was an error in the official CME settlement prices. The correction has been propagated to data providers, including Barchart, and the correct price of 1879.7 now appears in Sierra Chart.
