Date/Time: Tue, 04 Nov 2025 16:32:22 +0000
Data missing in Replay Chart mode
View Count: 771
| [2021-06-18 14:54:12] |
| Peter Beil - Posts: 19 |
Hi Guys, for some reason there is data missing/corrupt in my Footprint Chart (bottom right in the attached screenshot) when I use the Replay Chart mode. All other charts are correct - screen shot & chart settings attached. Anybody can help? Cheers Peter |
| [2021-06-18 15:17:42] |
| John - SC Support - Posts: 42755 |
That chart is not a Continuous Futures Contract, but your others are. Change that chart to match the Continuous settings for the other charts and you should be fine. Refer to the information here: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
