Date/Time: Tue, 04 Nov 2025 16:32:24 +0000
Highlight a bar vertically
View Count: 887
[2021-06-17 21:19:23]
User540504 - Posts: 15
Using the vertical line tool, I can have a line run through the candle (which obfuscates the wicks), or I can thicken it but it displays over the selected bar, obfuscating everything. I'm trying to accomplish something like the extending rectangle tool, but vertically over a single bar. I want to highlight it and I want it to be behind the bar so I can still see the OHLC.
Is there anything like this that currently exists?
[2021-06-17 22:29:43]
John - SC Support - Posts: 42755
You can use the Drawing Tool like you are, just be aware of this setting that controls whether it is drawn above the bars or below them:
Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
