Date/Time: Tue, 04 Nov 2025 16:32:22 +0000
Trading
View Count: 584
[2021-06-16 22:23:31]
NMH - Posts: 8
Can i trade directly through SC for non-professional realtime data, or do I still need an AMP equivalent. Do you guys recommend something over AMP these days? Thank you in advance, I know that you guys are busy!
[2021-06-17 13:43:27]
John - SC Support - Posts: 42755
You can trade directly from Sierra Chart as long as you are working with a broker/clearing firm that supports one of the trading services that we support. In the case of AMP, they support CQG which we work with. You will find the list of supported services here:
Supported Data and Trading Services: Supported Services
You can then drill down through each service to see a list of brokers that support each service.
In general, we recommend using the Sierra Chart Order Routing Service. For more information refer to the following:
Sierra Chart / Trading Technologies Futures Order Routing Service
Note the list of brokers in Step #2 of the Setup Instructions on the page above.
If you are asking if you can continue to get the data without a trading account, then the answer to that is that you can not get the CME Group data without proving that you have a live, funded, trading account at least once a month. That is the CME Group's rule.
