Date/Time: Tue, 04 Nov 2025 16:32:24 +0000
What Data Package should I get with Sierra Chart?
View Count: 624
| [2021-06-16 22:21:40] |
| User484164 - Posts: 4 |
I need delayed data for the futures contracts such as the emini S&P 500 and Oil. I also need two key chart indicators: 1.) a daily plot of Yesterday's H,L,O,C, and 2.) a cumulative market profile plot showing the high and low volume areas for data from the past year. I will execute trades using another platform. What do you recommend? Thanks.
| [2021-06-17 13:36:57] |
| John - SC Support - Posts: 42755 |
Since you need Market Profile, you will need the Advanced Package. If you can just use the Delayed Streaming data, then all you would need would be Package 5. Refer to the information on the packages here: Description of Service Packages and Pricing: Packages And refer to the information on the Delayed Streaming Data here: Delayed Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
