Date/Time: Tue, 04 Nov 2025 16:32:28 +0000
[User Discussion] - Contrat continu
View Count: 614
[2021-06-16 17:12:27]
Utilisateur188232 - Posts: 22
Bonjour, dans charts settings, avanced settings, continuous contract, que dois je mettre ?
imagecontinuous contract.JPG / V - Attached On 2021-06-16 17:11:53 UTC - Size: 319.18 KB - 203 views
imagecontinuous contract.JPG / V - Attached On 2021-06-16 17:12:19 UTC - Size: 319.18 KB - 208 views
[2021-06-16 17:30:13]
John - SC Support - Posts: 42755
From Google Translate:
Hello, in charts settings, advanced settings, continuous contract, what should I put?
It depends on how you want to see the historical data and when you want the rollover to take place. To start with, if you want the rollover to occur based on Volume, then choose a Volume based rollover. If you want rollover to be based on Date, then choose a Date Based rollover. The second thing to consider is whether you want the older data to be "Back Adjusted" or not.
For more information, refer to the information here:
Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options
[2021-06-16 21:53:37]
Quel est le plus utilisé en général ?
[2021-06-16 22:03:53]
What is the most used in general?
We see all choices from our perspective here, so we can't say there is one choice over another.
But, other user's may give their opinion on which rollover option they prefer and why.
