Date/Time: Tue, 04 Nov 2025 16:32:20 +0000
choix des services à prendre
View Count: 2115
[2021-06-16 16:20:47]
User143697 - Posts: 1
Bonjour, je souhaite utiliser sierra avec le carnet d'ordres, le time and sales, et le market profile, mon choix de la bourse est l'Eurex, je pensais prendre le package 12, mais je ne suis pas trop sûre de ce que cela inclut ? est ce que l'utilisation de la plateforme sierra est comprise dedans ? est ce que j'ai besoin d'autre choses ?
[2021-06-16 16:47:35]
John - SC Support - Posts: 42755
From Google Translate:
Hello, I want to use sierra with the order book, time and sales, and market profile, my choice of the exchange is Eurex, I was thinking of taking package 12, but I'm not sure what This includes ? is the use of the sierra platform included in this? do i need other things?
For what you are wanting, you would need the Advanced Service Package with the Denali Exchange Data Feed Fee (Package 11 at $46.00 USD per month before without multi-month discounts). And you would need to activate the EUREX exchange itself ($23 USD per month for Non-Professionals).
If you want the Market by Order data, then you would need Package 12 rather than Package 11. Refer to the following for the information on MBO:
Market By Order Data
We see that you are already on Package 12 and have the Denali Exchange Data Feed setup for the EUREX data. If you do not want the Market by Order information, then you could change your Package to Package 11 by following these instructions:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
