Date/Time: Tue, 04 Nov 2025 16:32:28 +0000
BID& ASK prices
View Count: 602
| [2021-06-16 16:16:14] |
| giudi - Posts: 5 |
The "BID & ASK price" study does not work: the lines are not continuous but stop at the last price. thank you https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=51957 |
| [2021-06-16 16:36:36] |
| John - SC Support - Posts: 42755 |
First, make sure the Subgraphs are set to what you want. It sounds like you want them to be a Line, which they should be by default, but it looks like this is not what you have set. Refer to the following: Chart Studies: Subgraphs Tab >> Draw Style Second, yes, the study stops at the current bar. If you want to show the lines extended to the right edge of the chart, then you could add the Study Subgraph Reference twice (once for each Bid and Ask) and then set the Draw Style of the Subgraph from those studies to be Line at Last Bar to Edge. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
