Date/Time: Tue, 04 Nov 2025 14:58:09 +0000
Spreadsheet Cell J31 not working
View Count: 761
|   [2021-06-16 11:52:24]     |
| User104854 - Posts: 460 |
                I'm using version 2256 and cell J31, max open position profit, in the spreadsheet for trading isn't accurate when trading live. I'm getting filled and the price is right at my entry and it says that my max open profit is $158,687.50. It doesn't seem to happen on SIM but definitely does live. Can you fix it?
|   [2021-06-16 12:21:16]     |
                It might be pulling a price value. I'm trading the 30 yr bond and the price is right at 158.6.  (Edit) Actually it is. My entry was at 158 22/32 which is 158.68750. The value in J31 was $158,687.50. Please fix. Date Time Of Last Edit: 2021-06-16 12:29:23
|   [2021-06-17 12:23:25]     |
                So.......  will this be addressed? I'd like to upgrade to the latest version but can't as I use this for another calculation that I use quite a bit.
|   [2021-06-18 07:09:38]     |
| Sierra_Chart Engineering - Posts: 21301 |
                We cannot reproduce this issue. See if you still have this issue on the latest version of Sierra Chart.  You will need to update.: Software Download: Fast Update Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2021-06-22 13:47:10]     |
                Appears to be working fine with version 2275.
