Date/Time: Tue, 04 Nov 2025 16:32:27 +0000
Delayed data lag
View Count: 759
| [2021-06-16 03:48:06] |
| User532947 - Posts: 17 |
Hi, The historical intraday data is delayed 2 hours + (not 10 mins). Please link me to info for the correct set-up. Note: I have the Standard Pack + Denali. I do not have a brokerage account so not all services have been activated. Currently I do not need Denali. Best regards |
| [2021-06-16 04:16:20] |
| Sierra_Chart Engineering - Posts: 21306 |
Tell us the symbol of the chart and then follow the instructions here: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-16 13:50:49] |
| John - SC Support - Posts: 42755 |
Also note that if you are not wanting Real-Time data from the Denali Exchange Data Feed, then you should not be on Package 10. You can change to package 3 and you will still have access to the delayed streaming data. To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-16 17:28:36] |
Symbols CL YM EC GC ES ... let me know when to clear the message log ... in the interim I'll change to Package 3 Many tks T
| [2021-06-16 17:31:37] |
Follow these instructions to get us your Message Log. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-16 18:13:30] |
GC Log Software version: 2253 64-bit | 2021-06-16 18:10:34.356 Primary Thread ID: 568 | 2021-06-16 18:10:34.356 Usage end date: 2021-09-08 | 2021-06-16 18:10:34.356 Enabled for: Sierra Chart Historical Data Service. | 2021-06-16 18:10:34.356 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-16 18:10:34.356 Allow Support for Sierra Chart Data Feeds is disabled. | 2021-06-16 18:10:34.356 Current selected Data/Trading service: SC Data - All Services | 2021-06-16 18:10:34.356 Custom symbol settings values: enabled | 2021-06-16 18:10:34.356 Chart Update Interval: 500 | 2021-06-16 18:10:34.356 Intraday Data Storage Time Unit: 0 | 2021-06-16 18:10:34.356 Time Zone: +00:00:00 (UTC+00) | 2021-06-16 18:10:34.356 2021-06-16 18:10:34 Local computer time in UTC | 2021-06-16 18:10:34.356 2021-06-16 18:10:34 Local computer time in SC Time Zone | 2021-06-16 18:10:34.356 2021-06-16 17:32:03 Server time in UTC | 2021-06-16 18:10:34.356 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-06-16 18:10:34.356 Program path: C:\SierraChart\ | 2021-06-16 18:10:34.356 Data Files path: C:\SierraChart\Data\ | 2021-06-16 18:10:34.356 OS Version Number: 10.0 | 2021-06-16 18:10:34.357 Locale Setting: C | 2021-06-16 18:10:34.357 DLLs: MAutoFloorCeiling.dll, MAutoFloorCeiling_2158.dll, MAutoFloorCeiling_2158_64.dll, MAutoFloorCeiling_64.dll, MBidAskOscillator.dll, MBidAskOscillator_2158.dll, MBidAskOscillator_2158_64.dll, MBidAskOscillator_64.dll, MBoxChart.dll, MBoxChart_2158.dll, MBoxChart_2158_64.dll, MBoxChart_64.dll, MBoxHistogram.dll, MBoxHistogram_2158.dll, MBoxHistogram_2158_64.dll, MBoxHistogram_64.dll, MCumulativeDelta.dll, MCumulativeDelta_2158.dll, MCumulativeDelta_2158_64.dll, MCumulativeDelta_64.dll, MGannSwing.dll, MGannSwing_2158.dll | 2021-06-16 18:10:34.357 Allowed protected custom studies: | 2021-06-16 18:10:34.357 File >> Disconnect selected. | 2021-06-16 18:11:20.716 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2021-06-16 18:11:20.858 DTC Client socket (3) | CloseSocket call. | 2021-06-16 18:11:20.858 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:20.859 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-06-16 18:11:20.859 SC Data - All Services | Disconnected. | 2021-06-16 18:11:20.859 SC Data - All Services | Connected to server complete. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 Mapping ESM21-CME to ESM21. Service code: cme | 2021-06-16 18:11:29.424 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESM21-CME (ESM21). ID: 1 Service code: cme | 2021-06-16 18:11:29.424 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10044 | 2021-06-16 18:11:29.424 SC DTC Delayed Exchange Data | Requesting security definition data for: ESM21-CME (ESM21). ID: 1 | 2021-06-16 18:11:29.424 Added historical Intraday data request for ESM21-CME to the queue. | 2021-06-16 18:11:29.424 Intraday data recording state for symbol ESM21-CME is set to download 'Pending'. | 2021-06-16 18:11:29.424 Triggering next historical data download in queue. | 2021-06-16 18:11:29.424 Delaying start of download for ESM21-CME | 2021-06-16 18:11:29.425 Mapping 6EU21-CME to 6EU21. Service code: cme | 2021-06-16 18:11:29.440 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6EU21-CME (6EU21). ID: 2 Service code: cme | 2021-06-16 18:11:29.440 SC DTC Delayed Exchange Data | Requesting security definition data for: 6EU21-CME (6EU21). ID: 2 | 2021-06-16 18:11:29.440 Added historical Intraday data request for 6EU21-CME to the queue. | 2021-06-16 18:11:29.440 Intraday data recording state for symbol 6EU21-CME is set to download 'Pending'. | 2021-06-16 18:11:29.440 Triggering next historical data download in queue. | 2021-06-16 18:11:29.440 Mapping GCQ21-COMEX to GCQ21. Service code: comex | 2021-06-16 18:11:29.442 SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCQ21-COMEX (GCQ21). ID: 3 Service code: comex | 2021-06-16 18:11:29.442 SC DTC Delayed Exchange Data | Requesting security definition data for: GCQ21-COMEX (GCQ21). ID: 3 | 2021-06-16 18:11:29.442 Added historical Intraday data request for GCQ21-COMEX to the queue. | 2021-06-16 18:11:29.442 Intraday data recording state for symbol GCQ21-COMEX is set to download 'Pending'. | 2021-06-16 18:11:29.442 Triggering next historical data download in queue. | 2021-06-16 18:11:29.442 DTC Client socket (5) | Creating socket. | 2021-06-16 18:11:29.445 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-16 18:11:29.445 DTC Client socket (5) | Connecting to IP: 204.15.197.13. | 2021-06-16 18:11:29.445 Mapping YMU21-CBOT to YMU21. Service code: cbot | 2021-06-16 18:11:29.706 SC DTC Delayed Exchange Data | Starting real-time market data updates for: YMU21-CBOT (YMU21). ID: 4 Service code: cbot | 2021-06-16 18:11:29.706 SC DTC Delayed Exchange Data | Requesting security definition data for: YMU21-CBOT (YMU21). ID: 4 | 2021-06-16 18:11:29.706 Added historical Intraday data request for YMU21-CBOT to the queue. | 2021-06-16 18:11:29.706 Intraday data recording state for symbol YMU21-CBOT is set to download 'Pending'. | 2021-06-16 18:11:29.706 Triggering next historical data download in queue. | 2021-06-16 18:11:29.706 Mapping CLN21-NYMEX to CLN21. Service code: nymex | 2021-06-16 18:11:29.719 Mapping CLQ21-NYMEX to CLQ21. Service code: nymex | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLQ21-NYMEX (CLQ21). ID: 6 Service code: nymex | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Requesting security definition data for: CLQ21-NYMEX (CLQ21). ID: 6 | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLN21-NYMEX (CLN21). ID: 5 Service code: nymex | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Requesting security definition data for: CLN21-NYMEX (CLN21). ID: 5 | 2021-06-16 18:11:29.719 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-16 18:11:29.719 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-16 18:11:29.719 Triggering next historical data download in queue. | 2021-06-16 18:11:29.719 Mapping TOF 01-01 U21.FUT_SPREAD.CBOT to TOF 01-01 U21.FUT_SPREAD.CBOT. Service code: cbot | 2021-06-16 18:11:29.732 SC DTC Delayed Exchange Data | Starting real-time market data updates for: TOF 01-01 U21.FUT_SPREAD.CBOT (TOF 01-01 U21.FUT_SPREAD.CBOT). ID: 7 Service code: cbot | 2021-06-16 18:11:29.732 SC DTC Delayed Exchange Data | Requesting security definition data for: TOF 01-01 U21.FUT_SPREAD.CBOT (TOF 01-01 U21.FUT_SPREAD.CBOT). ID: 7 | 2021-06-16 18:11:29.732 Added historical Intraday data request for TOF 01-01 U21.FUT_SPREAD.CBOT to the queue. | 2021-06-16 18:11:29.732 Intraday data recording state for symbol TOF 01-01 U21.FUT_SPREAD.CBOT is set to download 'Pending'. | 2021-06-16 18:11:29.732 Triggering next historical data download in queue. | 2021-06-16 18:11:29.732 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-06-16 18:11:30.000 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-06-16 18:11:30.000 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-16 18:11:30.001 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:30.132 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-06-16 18:11:30.132 SC DTC Delayed Exchange Data | Received logon response. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Successfully connected. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6EU21-CME -> 6EU21 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLN21-NYMEX -> CLN21 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLQ21-NYMEX -> CLQ21 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESM21-CME -> ESM21 | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: GCQ21-COMEX -> GCQ21 | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: TOF 01-01 U21.FUT_SPREAD.CBOT -> TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: YMU21-CBOT -> YMU21 | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Received security definition for symbol 6EU21-CME | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol CLN21-NYMEX | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol CLQ21-NYMEX | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol ESM21-CME | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol GCQ21-COMEX | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol YMU21-CBOT | 2021-06-16 18:11:31.100 HD Request # 20 | Downloading Intraday chart data for ESM21-CME to the file ESM21-CME.scid. Service: cme | 2021-06-16 18:11:36.871 HD Request # 20 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.468001 | 2021-06-16 18:11:36.872 HD Request # 20 | Using server: ds23.sierracharts.com port 10149 | 2021-06-16 18:11:36.872 Socket (6) | Creating socket. | 2021-06-16 18:11:36.872 Socket (6) | New receive buffer size: 5242880 | 2021-06-16 18:11:36.873 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-16 18:11:36.873 HD Request # 20 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:37.114 HD Request # 20 | Sending historical data logon request message. | 2021-06-16 18:11:37.114 HD Request # 20 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: ESM21 | 2021-06-16 18:11:37.698 HD Request # 20 | Decompressing data. | 2021-06-16 18:11:37.821 HD Request # 20 | Receiving Intraday data for ESM21-CME starting at 2021-06-16 18:01:09.071000 | 2021-06-16 18:11:37.935 Socket (6) | CloseSocket call. | 2021-06-16 18:11:37.937 Historical data download thread signaled to stop. | 2021-06-16 18:11:37.937 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:37.937 HD Request # 20 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.664000 | 2021-06-16 18:11:37.937 HD Request # 20 | Received 1086 records from 2021-06-16 18:01:09.071000 to 2021-06-16 18:01:35.953004 (26.9 seconds) and wrote 1071 records for ESM21-CME | 2021-06-16 18:11:37.938 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:35.953004 | 2021-06-16 18:11:37.939 HD Request # 20 | Completion time: 1s | 2021-06-16 18:11:37.939 HD Request # 20 | Intraday data download complete for ESM21-CME. Unique request ID: 20 | 2021-06-16 18:11:37.939 Removing historical data download ID 20. | 2021-06-16 18:11:37.939 Real-time Intraday chart data file updates started for ESM21-CME | 2021-06-16 18:11:37.939 Intraday chart data file opened for ESM21-CME | 2021-06-16 18:11:37.939 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:37.939 Triggering next historical data download in queue. | 2021-06-16 18:11:37.939 HD Request # 21 | Downloading Intraday chart data for 6EU21-CME to the file 6EU21-CME.scid. Service: cme | 2021-06-16 18:11:37.939 HD Request # 21 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.355000 | 2021-06-16 18:11:37.940 HD Request # 21 | Using server: ds21.sierracharts.com port 10150 | 2021-06-16 18:11:37.940 Socket (7) | Creating socket. | 2021-06-16 18:11:37.940 Socket (7) | New receive buffer size: 5242880 | 2021-06-16 18:11:37.940 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-06-16 18:11:37.940 Opened cached Intraday file: C:\SierraChart\Data\ESM21-CME.scid. Thread ID: 13352 | 2021-06-16 18:11:37.955 Socket (6) | Socket gracefully closed by remote side. | 2021-06-16 18:11:38.045 Socket (6) | Closed. | 2021-06-16 18:11:38.045 HD Request # 21 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:38.182 HD Request # 21 | Sending historical data logon request message. | 2021-06-16 18:11:38.182 HD Request # 21 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: 6EU21 | 2021-06-16 18:11:38.766 HD Request # 21 | Decompressing data. | 2021-06-16 18:11:38.888 HD Request # 21 | Receiving Intraday data for 6EU21-CME starting at 2021-06-16 18:01:09.024000 | 2021-06-16 18:11:38.893 Socket (7) | CloseSocket call. | 2021-06-16 18:11:38.895 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:38.896 Historical data download thread signaled to stop. | 2021-06-16 18:11:38.896 HD Request # 21 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.675000 | 2021-06-16 18:11:38.896 HD Request # 21 | Received 519 records from 2021-06-16 18:01:09.024000 to 2021-06-16 18:01:36.737001 (27.7 seconds) and wrote 514 records for 6EU21-CME | 2021-06-16 18:11:38.896 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:36.737001 | 2021-06-16 18:11:38.897 HD Request # 21 | Completion time: 1s | 2021-06-16 18:11:38.897 HD Request # 21 | Intraday data download complete for 6EU21-CME. Unique request ID: 21 | 2021-06-16 18:11:38.897 Removing historical data download ID 21. | 2021-06-16 18:11:38.897 Real-time Intraday chart data file updates started for 6EU21-CME | 2021-06-16 18:11:38.897 Intraday chart data file opened for 6EU21-CME | 2021-06-16 18:11:38.897 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:38.897 Triggering next historical data download in queue. | 2021-06-16 18:11:38.897 HD Request # 22 | Downloading Intraday chart data for GCQ21-COMEX to the file GCQ21-COMEX.scid. Service: comex | 2021-06-16 18:11:38.897 HD Request # 22 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.568000 | 2021-06-16 18:11:38.898 HD Request # 22 | Using server: ds23.sierracharts.com port 10149 | 2021-06-16 18:11:38.898 Socket (6) | Creating socket. | 2021-06-16 18:11:38.898 Socket (6) | New receive buffer size: 5242880 | 2021-06-16 18:11:38.898 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-16 18:11:38.898 Socket (7) | Socket gracefully closed by remote side. | 2021-06-16 18:11:39.009 Socket (7) | Closed. | 2021-06-16 18:11:39.009 HD Request # 22 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:39.139 HD Request # 22 | Sending historical data logon request message. | 2021-06-16 18:11:39.139 Opened cached Intraday file: C:\SierraChart\Data\6EU21-CME.scid. Thread ID: 13352 | 2021-06-16 18:11:39.143 HD Request # 22 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: GCQ21 | 2021-06-16 18:11:39.255 HD Request # 22 | Decompressing data. | 2021-06-16 18:11:39.382 HD Request # 22 | Receiving Intraday data for GCQ21-COMEX starting at 2021-06-16 18:01:09.025000 | 2021-06-16 18:11:39.546 Socket (6) | CloseSocket call. | 2021-06-16 18:11:39.548 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:39.549 Historical data download thread signaled to stop. | 2021-06-16 18:11:39.562 HD Request # 22 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.672000 | 2021-06-16 18:11:39.562 HD Request # 22 | Received 1067 records from 2021-06-16 18:01:09.025000 to 2021-06-16 18:01:37.584000 (28.6 seconds) and wrote 1052 records for GCQ21-COMEX | 2021-06-16 18:11:39.562 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:37.584000 | 2021-06-16 18:11:39.563 HD Request # 22 | Completion time: 1s | 2021-06-16 18:11:39.563 HD Request # 22 | Intraday data download complete for GCQ21-COMEX. Unique request ID: 22 | 2021-06-16 18:11:39.563 Removing historical data download ID 22. | 2021-06-16 18:11:39.563 Real-time Intraday chart data file updates started for GCQ21-COMEX | 2021-06-16 18:11:39.563 Intraday chart data file opened for GCQ21-COMEX | 2021-06-16 18:11:39.563 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:39.563 Triggering next historical data download in queue. | 2021-06-16 18:11:39.564 HD Request # 23 | Downloading Intraday chart data for YMU21-CBOT to the file YMU21-CBOT.scid. Service: cbot | 2021-06-16 18:11:39.564 HD Request # 23 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.394000 | 2021-06-16 18:11:39.564 HD Request # 23 | Using server: ds21.sierracharts.com port 10150 | 2021-06-16 18:11:39.565 Socket (7) | Creating socket. | 2021-06-16 18:11:39.565 Socket (7) | New receive buffer size: 5242880 | 2021-06-16 18:11:39.565 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-06-16 18:11:39.565 Socket (6) | Socket gracefully closed by remote side. | 2021-06-16 18:11:39.659 Socket (6) | Closed. | 2021-06-16 18:11:39.659 Opened cached Intraday file: C:\SierraChart\Data\GCQ21-COMEX.scid. Thread ID: 13352 | 2021-06-16 18:11:39.712 HD Request # 23 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:39.794 HD Request # 23 | Sending historical data logon request message. | 2021-06-16 18:11:39.794 HD Request # 23 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: YMU21 | 2021-06-16 18:11:39.904 HD Request # 23 | Decompressing data. | 2021-06-16 18:11:40.014 HD Request # 23 | Receiving Intraday data for YMU21-CBOT starting at 2021-06-16 18:01:09.043000 | 2021-06-16 18:11:40.020 Socket (7) | CloseSocket call. | 2021-06-16 18:11:40.132 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:40.133 Historical data download thread signaled to stop. | 2021-06-16 18:11:40.133 HD Request # 23 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.565000 | 2021-06-16 18:11:40.133 HD Request # 23 | Received 1045 records from 2021-06-16 18:01:09.043000 to 2021-06-16 18:01:37.974000 (28.9 seconds) and wrote 998 records for YMU21-CBOT | 2021-06-16 18:11:40.133 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:37.974000 | 2021-06-16 18:11:40.134 HD Request # 23 | Completion time: 1s | 2021-06-16 18:11:40.134 HD Request # 23 | Intraday data download complete for YMU21-CBOT. Unique request ID: 23 | 2021-06-16 18:11:40.134 Removing historical data download ID 23. | 2021-06-16 18:11:40.134 Real-time Intraday chart data file updates started for YMU21-CBOT | 2021-06-16 18:11:40.134 Intraday chart data file opened for YMU21-CBOT | 2021-06-16 18:11:40.134 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:40.134 Triggering next historical data download in queue. | 2021-06-16 18:11:40.134 HD Request # 24 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-16 18:11:40.134 HD Request # 24 | Download start date-time: 2021-06-16 17:22:44.000000. File last date-time: 2021-06-16 17:22:44.502001 | 2021-06-16 18:11:40.135 HD Request # 24 | Using server: ds23.sierracharts.com port 10149 | 2021-06-16 18:11:40.135 Socket (6) | Creating socket. | 2021-06-16 18:11:40.135 Socket (6) | New receive buffer size: 5242880 | 2021-06-16 18:11:40.135 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-16 18:11:40.135 Opened cached Intraday file: C:\SierraChart\Data\YMU21-CBOT.scid. Thread ID: 13352 | 2021-06-16 18:11:40.139 Socket (7) | Socket gracefully closed by remote side. | 2021-06-16 18:11:40.242 Socket (7) | Closed. | 2021-06-16 18:11:40.242 HD Request # 24 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:40.373 HD Request # 24 | Sending historical data logon request message. | 2021-06-16 18:11:40.373 HD Request # 24 | Requesting Intraday data. Start date-time: 2021-06-16 17:22:44. Record interval: 0. Symbol: CLN21 | 2021-06-16 18:11:40.482 HD Request # 24 | Decompressing data. | 2021-06-16 18:11:40.594 HD Request # 24 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-16 17:22:44.502000 | 2021-06-16 18:11:40.952 Socket (6) | CloseSocket call. | 2021-06-16 18:11:40.959 Historical data download thread signaled to stop. | 2021-06-16 18:11:40.959 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:40.959 HD Request # 24 | Timestamp of first Intraday data file record written: 2021-06-16 17:22:47.778000 | 2021-06-16 18:11:40.959 HD Request # 24 | Received 7381 records from 2021-06-16 17:22:44.502000 to 2021-06-16 18:01:38.810000 (38.9 minutes) and wrote 7379 records for CLN21-NYMEX | 2021-06-16 18:11:40.960 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:38.810000 | 2021-06-16 18:11:40.961 HD Request # 24 | Completion time: 0s | 2021-06-16 18:11:40.961 HD Request # 24 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 24 | 2021-06-16 18:11:40.961 Removing historical data download ID 24. | 2021-06-16 18:11:40.961 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-16 18:11:40.961 Intraday chart data file opened for CLN21-NYMEX | 2021-06-16 18:11:40.961 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:40.961 Triggering next historical data download in queue. | 2021-06-16 18:11:40.961 HD Request # 25 | Downloading Intraday chart data for TOF 01-01 U21.FUT_SPREAD.CBOT to the file TOF 01-01 U21.FUT_SPREAD.CBOT.scid. Service: cbot | 2021-06-16 18:11:40.961 HD Request # 25 | Download start date-time: 2021-06-16 18:01:07.000000. File last date-time: 2021-06-16 18:01:07.282001 | 2021-06-16 18:11:40.962 HD Request # 25 | Using server: ds21.sierracharts.com port 10150 | 2021-06-16 18:11:40.962 Socket (7) | Creating socket. | 2021-06-16 18:11:40.962 Socket (7) | New receive buffer size: 5242880 | 2021-06-16 18:11:40.962 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-06-16 18:11:40.962 Socket (6) | Socket gracefully closed by remote side. | 2021-06-16 18:11:41.093 Socket (6) | Closed. | 2021-06-16 18:11:41.093 Opened cached Intraday file: C:\SierraChart\Data\CLN21-NYMEX.scid. Thread ID: 13352 | 2021-06-16 18:11:41.127 HD Request # 25 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:41.205 HD Request # 25 | Sending historical data logon request message. | 2021-06-16 18:11:41.205 HD Request # 25 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:07. Record interval: 0. Symbol: TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.319 HD Request # 25 | Decompressing data. | 2021-06-16 18:11:41.432 HD Request # 25 | Receiving Intraday data for TOF 01-01 U21.FUT_SPREAD.CBOT starting at 2021-06-16 18:01:07.277000 | 2021-06-16 18:11:41.435 Socket (7) | CloseSocket call. | 2021-06-16 18:11:41.436 Historical data download thread signaled to stop. | 2021-06-16 18:11:41.437 HD Request # 25 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:36.009000 | 2021-06-16 18:11:41.437 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:41.437 HD Request # 25 | Received 9 records from 2021-06-16 18:01:07.277000 to 2021-06-16 18:01:37.701000 (30.4 seconds) and wrote 3 records for TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.437 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:37.701000 | 2021-06-16 18:11:41.438 HD Request # 25 | Completion time: 1s | 2021-06-16 18:11:41.438 HD Request # 25 | Intraday data download complete for TOF 01-01 U21.FUT_SPREAD.CBOT. Unique request ID: 25 | 2021-06-16 18:11:41.438 Removing historical data download ID 25. | 2021-06-16 18:11:41.438 Real-time Intraday chart data file updates started for TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.438 Intraday chart data file opened for TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.438 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:41.438 Triggering next historical data download in queue. | 2021-06-16 18:11:41.438 No download requests in the queue to start downloads for. | 2021-06-16 18:11:41.439 Socket (7) | Socket gracefully closed by remote side. | 2021-06-16 18:11:41.548 Socket (7) | Closed. | 2021-06-16 18:11:41.548 |
| [2021-06-16 18:14:51] |
CL Log Software version: 2253 64-bit | 2021-06-16 18:10:34.356 Primary Thread ID: 568 | 2021-06-16 18:10:34.356 Usage end date: 2021-09-08 | 2021-06-16 18:10:34.356 Enabled for: Sierra Chart Historical Data Service. | 2021-06-16 18:10:34.356 Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-16 18:10:34.356 Allow Support for Sierra Chart Data Feeds is disabled. | 2021-06-16 18:10:34.356 Current selected Data/Trading service: SC Data - All Services | 2021-06-16 18:10:34.356 Custom symbol settings values: enabled | 2021-06-16 18:10:34.356 Chart Update Interval: 500 | 2021-06-16 18:10:34.356 Intraday Data Storage Time Unit: 0 | 2021-06-16 18:10:34.356 Time Zone: +00:00:00 (UTC+00) | 2021-06-16 18:10:34.356 2021-06-16 18:10:34 Local computer time in UTC | 2021-06-16 18:10:34.356 2021-06-16 18:10:34 Local computer time in SC Time Zone | 2021-06-16 18:10:34.356 2021-06-16 17:32:03 Server time in UTC | 2021-06-16 18:10:34.356 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-06-16 18:10:34.356 Program path: C:\SierraChart\ | 2021-06-16 18:10:34.356 Data Files path: C:\SierraChart\Data\ | 2021-06-16 18:10:34.356 OS Version Number: 10.0 | 2021-06-16 18:10:34.357 Locale Setting: C | 2021-06-16 18:10:34.357 DLLs: MAutoFloorCeiling.dll, MAutoFloorCeiling_2158.dll, MAutoFloorCeiling_2158_64.dll, MAutoFloorCeiling_64.dll, MBidAskOscillator.dll, MBidAskOscillator_2158.dll, MBidAskOscillator_2158_64.dll, MBidAskOscillator_64.dll, MBoxChart.dll, MBoxChart_2158.dll, MBoxChart_2158_64.dll, MBoxChart_64.dll, MBoxHistogram.dll, MBoxHistogram_2158.dll, MBoxHistogram_2158_64.dll, MBoxHistogram_64.dll, MCumulativeDelta.dll, MCumulativeDelta_2158.dll, MCumulativeDelta_2158_64.dll, MCumulativeDelta_64.dll, MGannSwing.dll, MGannSwing_2158.dll | 2021-06-16 18:10:34.357 Allowed protected custom studies: | 2021-06-16 18:10:34.357 File >> Disconnect selected. | 2021-06-16 18:11:20.716 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2021-06-16 18:11:20.858 DTC Client socket (3) | CloseSocket call. | 2021-06-16 18:11:20.858 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:20.859 SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-06-16 18:11:20.859 SC Data - All Services | Disconnected. | 2021-06-16 18:11:20.859 SC Data - All Services | Connected to server complete. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 Triggering next historical data download in queue. | 2021-06-16 18:11:29.266 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 No download requests in the queue to start downloads for. | 2021-06-16 18:11:29.404 Mapping ESM21-CME to ESM21. Service code: cme | 2021-06-16 18:11:29.424 SC DTC Delayed Exchange Data | Starting real-time market data updates for: ESM21-CME (ESM21). ID: 1 Service code: cme | 2021-06-16 18:11:29.424 SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10044 | 2021-06-16 18:11:29.424 SC DTC Delayed Exchange Data | Requesting security definition data for: ESM21-CME (ESM21). ID: 1 | 2021-06-16 18:11:29.424 Added historical Intraday data request for ESM21-CME to the queue. | 2021-06-16 18:11:29.424 Intraday data recording state for symbol ESM21-CME is set to download 'Pending'. | 2021-06-16 18:11:29.424 Triggering next historical data download in queue. | 2021-06-16 18:11:29.424 Delaying start of download for ESM21-CME | 2021-06-16 18:11:29.425 Mapping 6EU21-CME to 6EU21. Service code: cme | 2021-06-16 18:11:29.440 SC DTC Delayed Exchange Data | Starting real-time market data updates for: 6EU21-CME (6EU21). ID: 2 Service code: cme | 2021-06-16 18:11:29.440 SC DTC Delayed Exchange Data | Requesting security definition data for: 6EU21-CME (6EU21). ID: 2 | 2021-06-16 18:11:29.440 Added historical Intraday data request for 6EU21-CME to the queue. | 2021-06-16 18:11:29.440 Intraday data recording state for symbol 6EU21-CME is set to download 'Pending'. | 2021-06-16 18:11:29.440 Triggering next historical data download in queue. | 2021-06-16 18:11:29.440 Mapping GCQ21-COMEX to GCQ21. Service code: comex | 2021-06-16 18:11:29.442 SC DTC Delayed Exchange Data | Starting real-time market data updates for: GCQ21-COMEX (GCQ21). ID: 3 Service code: comex | 2021-06-16 18:11:29.442 SC DTC Delayed Exchange Data | Requesting security definition data for: GCQ21-COMEX (GCQ21). ID: 3 | 2021-06-16 18:11:29.442 Added historical Intraday data request for GCQ21-COMEX to the queue. | 2021-06-16 18:11:29.442 Intraday data recording state for symbol GCQ21-COMEX is set to download 'Pending'. | 2021-06-16 18:11:29.442 Triggering next historical data download in queue. | 2021-06-16 18:11:29.442 DTC Client socket (5) | Creating socket. | 2021-06-16 18:11:29.445 DTC Client socket (5) | New receive buffer size: 5242880 | 2021-06-16 18:11:29.445 DTC Client socket (5) | Connecting to IP: 204.15.197.13. | 2021-06-16 18:11:29.445 Mapping YMU21-CBOT to YMU21. Service code: cbot | 2021-06-16 18:11:29.706 SC DTC Delayed Exchange Data | Starting real-time market data updates for: YMU21-CBOT (YMU21). ID: 4 Service code: cbot | 2021-06-16 18:11:29.706 SC DTC Delayed Exchange Data | Requesting security definition data for: YMU21-CBOT (YMU21). ID: 4 | 2021-06-16 18:11:29.706 Added historical Intraday data request for YMU21-CBOT to the queue. | 2021-06-16 18:11:29.706 Intraday data recording state for symbol YMU21-CBOT is set to download 'Pending'. | 2021-06-16 18:11:29.706 Triggering next historical data download in queue. | 2021-06-16 18:11:29.706 Mapping CLN21-NYMEX to CLN21. Service code: nymex | 2021-06-16 18:11:29.719 Mapping CLQ21-NYMEX to CLQ21. Service code: nymex | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLQ21-NYMEX (CLQ21). ID: 6 Service code: nymex | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Requesting security definition data for: CLQ21-NYMEX (CLQ21). ID: 6 | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Starting real-time market data updates for: CLN21-NYMEX (CLN21). ID: 5 Service code: nymex | 2021-06-16 18:11:29.719 SC DTC Delayed Exchange Data | Requesting security definition data for: CLN21-NYMEX (CLN21). ID: 5 | 2021-06-16 18:11:29.719 Added historical Intraday data request for CLN21-NYMEX to the queue. | 2021-06-16 18:11:29.719 Intraday data recording state for symbol CLN21-NYMEX is set to download 'Pending'. | 2021-06-16 18:11:29.719 Triggering next historical data download in queue. | 2021-06-16 18:11:29.719 Mapping TOF 01-01 U21.FUT_SPREAD.CBOT to TOF 01-01 U21.FUT_SPREAD.CBOT. Service code: cbot | 2021-06-16 18:11:29.732 SC DTC Delayed Exchange Data | Starting real-time market data updates for: TOF 01-01 U21.FUT_SPREAD.CBOT (TOF 01-01 U21.FUT_SPREAD.CBOT). ID: 7 Service code: cbot | 2021-06-16 18:11:29.732 SC DTC Delayed Exchange Data | Requesting security definition data for: TOF 01-01 U21.FUT_SPREAD.CBOT (TOF 01-01 U21.FUT_SPREAD.CBOT). ID: 7 | 2021-06-16 18:11:29.732 Added historical Intraday data request for TOF 01-01 U21.FUT_SPREAD.CBOT to the queue. | 2021-06-16 18:11:29.732 Intraday data recording state for symbol TOF 01-01 U21.FUT_SPREAD.CBOT is set to download 'Pending'. | 2021-06-16 18:11:29.732 Triggering next historical data download in queue. | 2021-06-16 18:11:29.732 SC DTC Delayed Exchange Data | Network connection to server complete. | 2021-06-16 18:11:30.000 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2021-06-16 18:11:30.000 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-16 18:11:30.001 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:30.132 SC DTC Delayed Exchange Data | Sending logon request message. | 2021-06-16 18:11:30.132 SC DTC Delayed Exchange Data | Received logon response. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Successfully connected. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Trading is not supported. | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: 6EU21-CME -> 6EU21 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLN21-NYMEX -> CLN21 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: CLQ21-NYMEX -> CLQ21 | 2021-06-16 18:11:30.880 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: ESM21-CME -> ESM21 | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: GCQ21-COMEX -> GCQ21 | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: TOF 01-01 U21.FUT_SPREAD.CBOT -> TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: YMU21-CBOT -> YMU21 | 2021-06-16 18:11:30.881 SC DTC Delayed Exchange Data | Received security definition for symbol 6EU21-CME | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol CLN21-NYMEX | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol CLQ21-NYMEX | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol ESM21-CME | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol GCQ21-COMEX | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:31.100 SC DTC Delayed Exchange Data | Received security definition for symbol YMU21-CBOT | 2021-06-16 18:11:31.100 HD Request # 20 | Downloading Intraday chart data for ESM21-CME to the file ESM21-CME.scid. Service: cme | 2021-06-16 18:11:36.871 HD Request # 20 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.468001 | 2021-06-16 18:11:36.872 HD Request # 20 | Using server: ds23.sierracharts.com port 10149 | 2021-06-16 18:11:36.872 Socket (6) | Creating socket. | 2021-06-16 18:11:36.872 Socket (6) | New receive buffer size: 5242880 | 2021-06-16 18:11:36.873 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-16 18:11:36.873 HD Request # 20 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:37.114 HD Request # 20 | Sending historical data logon request message. | 2021-06-16 18:11:37.114 HD Request # 20 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: ESM21 | 2021-06-16 18:11:37.698 HD Request # 20 | Decompressing data. | 2021-06-16 18:11:37.821 HD Request # 20 | Receiving Intraday data for ESM21-CME starting at 2021-06-16 18:01:09.071000 | 2021-06-16 18:11:37.935 Socket (6) | CloseSocket call. | 2021-06-16 18:11:37.937 Historical data download thread signaled to stop. | 2021-06-16 18:11:37.937 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:37.937 HD Request # 20 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.664000 | 2021-06-16 18:11:37.937 HD Request # 20 | Received 1086 records from 2021-06-16 18:01:09.071000 to 2021-06-16 18:01:35.953004 (26.9 seconds) and wrote 1071 records for ESM21-CME | 2021-06-16 18:11:37.938 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:35.953004 | 2021-06-16 18:11:37.939 HD Request # 20 | Completion time: 1s | 2021-06-16 18:11:37.939 HD Request # 20 | Intraday data download complete for ESM21-CME. Unique request ID: 20 | 2021-06-16 18:11:37.939 Removing historical data download ID 20. | 2021-06-16 18:11:37.939 Real-time Intraday chart data file updates started for ESM21-CME | 2021-06-16 18:11:37.939 Intraday chart data file opened for ESM21-CME | 2021-06-16 18:11:37.939 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:37.939 Triggering next historical data download in queue. | 2021-06-16 18:11:37.939 HD Request # 21 | Downloading Intraday chart data for 6EU21-CME to the file 6EU21-CME.scid. Service: cme | 2021-06-16 18:11:37.939 HD Request # 21 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.355000 | 2021-06-16 18:11:37.940 HD Request # 21 | Using server: ds21.sierracharts.com port 10150 | 2021-06-16 18:11:37.940 Socket (7) | Creating socket. | 2021-06-16 18:11:37.940 Socket (7) | New receive buffer size: 5242880 | 2021-06-16 18:11:37.940 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-06-16 18:11:37.940 Opened cached Intraday file: C:\SierraChart\Data\ESM21-CME.scid. Thread ID: 13352 | 2021-06-16 18:11:37.955 Socket (6) | Socket gracefully closed by remote side. | 2021-06-16 18:11:38.045 Socket (6) | Closed. | 2021-06-16 18:11:38.045 HD Request # 21 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:38.182 HD Request # 21 | Sending historical data logon request message. | 2021-06-16 18:11:38.182 HD Request # 21 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: 6EU21 | 2021-06-16 18:11:38.766 HD Request # 21 | Decompressing data. | 2021-06-16 18:11:38.888 HD Request # 21 | Receiving Intraday data for 6EU21-CME starting at 2021-06-16 18:01:09.024000 | 2021-06-16 18:11:38.893 Socket (7) | CloseSocket call. | 2021-06-16 18:11:38.895 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:38.896 Historical data download thread signaled to stop. | 2021-06-16 18:11:38.896 HD Request # 21 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.675000 | 2021-06-16 18:11:38.896 HD Request # 21 | Received 519 records from 2021-06-16 18:01:09.024000 to 2021-06-16 18:01:36.737001 (27.7 seconds) and wrote 514 records for 6EU21-CME | 2021-06-16 18:11:38.896 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:36.737001 | 2021-06-16 18:11:38.897 HD Request # 21 | Completion time: 1s | 2021-06-16 18:11:38.897 HD Request # 21 | Intraday data download complete for 6EU21-CME. Unique request ID: 21 | 2021-06-16 18:11:38.897 Removing historical data download ID 21. | 2021-06-16 18:11:38.897 Real-time Intraday chart data file updates started for 6EU21-CME | 2021-06-16 18:11:38.897 Intraday chart data file opened for 6EU21-CME | 2021-06-16 18:11:38.897 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:38.897 Triggering next historical data download in queue. | 2021-06-16 18:11:38.897 HD Request # 22 | Downloading Intraday chart data for GCQ21-COMEX to the file GCQ21-COMEX.scid. Service: comex | 2021-06-16 18:11:38.897 HD Request # 22 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.568000 | 2021-06-16 18:11:38.898 HD Request # 22 | Using server: ds23.sierracharts.com port 10149 | 2021-06-16 18:11:38.898 Socket (6) | Creating socket. | 2021-06-16 18:11:38.898 Socket (6) | New receive buffer size: 5242880 | 2021-06-16 18:11:38.898 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-16 18:11:38.898 Socket (7) | Socket gracefully closed by remote side. | 2021-06-16 18:11:39.009 Socket (7) | Closed. | 2021-06-16 18:11:39.009 HD Request # 22 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:39.139 HD Request # 22 | Sending historical data logon request message. | 2021-06-16 18:11:39.139 Opened cached Intraday file: C:\SierraChart\Data\6EU21-CME.scid. Thread ID: 13352 | 2021-06-16 18:11:39.143 HD Request # 22 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: GCQ21 | 2021-06-16 18:11:39.255 HD Request # 22 | Decompressing data. | 2021-06-16 18:11:39.382 HD Request # 22 | Receiving Intraday data for GCQ21-COMEX starting at 2021-06-16 18:01:09.025000 | 2021-06-16 18:11:39.546 Socket (6) | CloseSocket call. | 2021-06-16 18:11:39.548 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:39.549 Historical data download thread signaled to stop. | 2021-06-16 18:11:39.562 HD Request # 22 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.672000 | 2021-06-16 18:11:39.562 HD Request # 22 | Received 1067 records from 2021-06-16 18:01:09.025000 to 2021-06-16 18:01:37.584000 (28.6 seconds) and wrote 1052 records for GCQ21-COMEX | 2021-06-16 18:11:39.562 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:37.584000 | 2021-06-16 18:11:39.563 HD Request # 22 | Completion time: 1s | 2021-06-16 18:11:39.563 HD Request # 22 | Intraday data download complete for GCQ21-COMEX. Unique request ID: 22 | 2021-06-16 18:11:39.563 Removing historical data download ID 22. | 2021-06-16 18:11:39.563 Real-time Intraday chart data file updates started for GCQ21-COMEX | 2021-06-16 18:11:39.563 Intraday chart data file opened for GCQ21-COMEX | 2021-06-16 18:11:39.563 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:39.563 Triggering next historical data download in queue. | 2021-06-16 18:11:39.564 HD Request # 23 | Downloading Intraday chart data for YMU21-CBOT to the file YMU21-CBOT.scid. Service: cbot | 2021-06-16 18:11:39.564 HD Request # 23 | Download start date-time: 2021-06-16 18:01:09.000000. File last date-time: 2021-06-16 18:01:09.394000 | 2021-06-16 18:11:39.564 HD Request # 23 | Using server: ds21.sierracharts.com port 10150 | 2021-06-16 18:11:39.565 Socket (7) | Creating socket. | 2021-06-16 18:11:39.565 Socket (7) | New receive buffer size: 5242880 | 2021-06-16 18:11:39.565 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-06-16 18:11:39.565 Socket (6) | Socket gracefully closed by remote side. | 2021-06-16 18:11:39.659 Socket (6) | Closed. | 2021-06-16 18:11:39.659 Opened cached Intraday file: C:\SierraChart\Data\GCQ21-COMEX.scid. Thread ID: 13352 | 2021-06-16 18:11:39.712 HD Request # 23 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:39.794 HD Request # 23 | Sending historical data logon request message. | 2021-06-16 18:11:39.794 HD Request # 23 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:09. Record interval: 0. Symbol: YMU21 | 2021-06-16 18:11:39.904 HD Request # 23 | Decompressing data. | 2021-06-16 18:11:40.014 HD Request # 23 | Receiving Intraday data for YMU21-CBOT starting at 2021-06-16 18:01:09.043000 | 2021-06-16 18:11:40.020 Socket (7) | CloseSocket call. | 2021-06-16 18:11:40.132 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:40.133 Historical data download thread signaled to stop. | 2021-06-16 18:11:40.133 HD Request # 23 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:09.565000 | 2021-06-16 18:11:40.133 HD Request # 23 | Received 1045 records from 2021-06-16 18:01:09.043000 to 2021-06-16 18:01:37.974000 (28.9 seconds) and wrote 998 records for YMU21-CBOT | 2021-06-16 18:11:40.133 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:37.974000 | 2021-06-16 18:11:40.134 HD Request # 23 | Completion time: 1s | 2021-06-16 18:11:40.134 HD Request # 23 | Intraday data download complete for YMU21-CBOT. Unique request ID: 23 | 2021-06-16 18:11:40.134 Removing historical data download ID 23. | 2021-06-16 18:11:40.134 Real-time Intraday chart data file updates started for YMU21-CBOT | 2021-06-16 18:11:40.134 Intraday chart data file opened for YMU21-CBOT | 2021-06-16 18:11:40.134 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:40.134 Triggering next historical data download in queue. | 2021-06-16 18:11:40.134 HD Request # 24 | Downloading Intraday chart data for CLN21-NYMEX to the file CLN21-NYMEX.scid. Service: nymex | 2021-06-16 18:11:40.134 HD Request # 24 | Download start date-time: 2021-06-16 17:22:44.000000. File last date-time: 2021-06-16 17:22:44.502001 | 2021-06-16 18:11:40.135 HD Request # 24 | Using server: ds23.sierracharts.com port 10149 | 2021-06-16 18:11:40.135 Socket (6) | Creating socket. | 2021-06-16 18:11:40.135 Socket (6) | New receive buffer size: 5242880 | 2021-06-16 18:11:40.135 Socket (6) | Connecting to IP: 216.1.90.130. | 2021-06-16 18:11:40.135 Opened cached Intraday file: C:\SierraChart\Data\YMU21-CBOT.scid. Thread ID: 13352 | 2021-06-16 18:11:40.139 Socket (7) | Socket gracefully closed by remote side. | 2021-06-16 18:11:40.242 Socket (7) | Closed. | 2021-06-16 18:11:40.242 HD Request # 24 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:40.373 HD Request # 24 | Sending historical data logon request message. | 2021-06-16 18:11:40.373 HD Request # 24 | Requesting Intraday data. Start date-time: 2021-06-16 17:22:44. Record interval: 0. Symbol: CLN21 | 2021-06-16 18:11:40.482 HD Request # 24 | Decompressing data. | 2021-06-16 18:11:40.594 HD Request # 24 | Receiving Intraday data for CLN21-NYMEX starting at 2021-06-16 17:22:44.502000 | 2021-06-16 18:11:40.952 Socket (6) | CloseSocket call. | 2021-06-16 18:11:40.959 Historical data download thread signaled to stop. | 2021-06-16 18:11:40.959 Socket (6) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:40.959 HD Request # 24 | Timestamp of first Intraday data file record written: 2021-06-16 17:22:47.778000 | 2021-06-16 18:11:40.959 HD Request # 24 | Received 7381 records from 2021-06-16 17:22:44.502000 to 2021-06-16 18:01:38.810000 (38.9 minutes) and wrote 7379 records for CLN21-NYMEX | 2021-06-16 18:11:40.960 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:38.810000 | 2021-06-16 18:11:40.961 HD Request # 24 | Completion time: 0s | 2021-06-16 18:11:40.961 HD Request # 24 | Intraday data download complete for CLN21-NYMEX. Unique request ID: 24 | 2021-06-16 18:11:40.961 Removing historical data download ID 24. | 2021-06-16 18:11:40.961 Real-time Intraday chart data file updates started for CLN21-NYMEX | 2021-06-16 18:11:40.961 Intraday chart data file opened for CLN21-NYMEX | 2021-06-16 18:11:40.961 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:40.961 Triggering next historical data download in queue. | 2021-06-16 18:11:40.961 HD Request # 25 | Downloading Intraday chart data for TOF 01-01 U21.FUT_SPREAD.CBOT to the file TOF 01-01 U21.FUT_SPREAD.CBOT.scid. Service: cbot | 2021-06-16 18:11:40.961 HD Request # 25 | Download start date-time: 2021-06-16 18:01:07.000000. File last date-time: 2021-06-16 18:01:07.282001 | 2021-06-16 18:11:40.962 HD Request # 25 | Using server: ds21.sierracharts.com port 10150 | 2021-06-16 18:11:40.962 Socket (7) | Creating socket. | 2021-06-16 18:11:40.962 Socket (7) | New receive buffer size: 5242880 | 2021-06-16 18:11:40.962 Socket (7) | Connecting to IP: 216.1.90.129. | 2021-06-16 18:11:40.962 Socket (6) | Socket gracefully closed by remote side. | 2021-06-16 18:11:41.093 Socket (6) | Closed. | 2021-06-16 18:11:41.093 Opened cached Intraday file: C:\SierraChart\Data\CLN21-NYMEX.scid. Thread ID: 13352 | 2021-06-16 18:11:41.127 HD Request # 25 | Setting DTC encoding to Binary VLS | 2021-06-16 18:11:41.205 HD Request # 25 | Sending historical data logon request message. | 2021-06-16 18:11:41.205 HD Request # 25 | Requesting Intraday data. Start date-time: 2021-06-16 18:01:07. Record interval: 0. Symbol: TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.319 HD Request # 25 | Decompressing data. | 2021-06-16 18:11:41.432 HD Request # 25 | Receiving Intraday data for TOF 01-01 U21.FUT_SPREAD.CBOT starting at 2021-06-16 18:01:07.277000 | 2021-06-16 18:11:41.435 Socket (7) | CloseSocket call. | 2021-06-16 18:11:41.436 Historical data download thread signaled to stop. | 2021-06-16 18:11:41.437 HD Request # 25 | Timestamp of first Intraday data file record written: 2021-06-16 18:01:36.009000 | 2021-06-16 18:11:41.437 Socket (7) | Shutdown started. Waiting for graceful close. | 2021-06-16 18:11:41.437 HD Request # 25 | Received 9 records from 2021-06-16 18:01:07.277000 to 2021-06-16 18:01:37.701000 (30.4 seconds) and wrote 3 records for TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.437 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2021-06-16 18:01:37.701000 | 2021-06-16 18:11:41.438 HD Request # 25 | Completion time: 1s | 2021-06-16 18:11:41.438 HD Request # 25 | Intraday data download complete for TOF 01-01 U21.FUT_SPREAD.CBOT. Unique request ID: 25 | 2021-06-16 18:11:41.438 Removing historical data download ID 25. | 2021-06-16 18:11:41.438 Real-time Intraday chart data file updates started for TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.438 Intraday chart data file opened for TOF 01-01 U21.FUT_SPREAD.CBOT | 2021-06-16 18:11:41.438 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2021-06-16 18:11:41.438 Triggering next historical data download in queue. | 2021-06-16 18:11:41.438 No download requests in the queue to start downloads for. | 2021-06-16 18:11:41.439 Socket (7) | Socket gracefully closed by remote side. | 2021-06-16 18:11:41.548 Socket (7) | Closed. | 2021-06-16 18:11:41.548 DTC Client socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-06-16 18:13:29.750 DTC Client socket (3) | Closed. | 2021-06-16 18:13:29.750 |
| [2021-06-16 18:25:15] |
The log shows that you are getting data up to the 10 minutes prior to the current time. Your Global Time Zone is set to UTC and you have a line like this: HD Request # 22 | Received 1067 records from 2021-06-16 18:01:09.025000 to 2021-06-16 18:01:37.584000 (28.6 seconds) and wrote 1052 records for GCQ21-COMEX | 2021-06-16 18:11:39.562
Which shows that you received historical data up to 2021-06-16 18:01:37 which occurred at 2021-06-16 18:11:39. Are you still having an issue? If so, please take an image of one of your charts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-16 19:55:20] |
Here's CL @21:53 CET. The last paint is at 19:49 http://www.sierrachart.com/image.php?Image=1623873190207.png |
| Attachment Deleted. |
| [2021-06-16 20:31:33] |
You will notice that the DD in the upper right corner of the screen is showing a delay of just 10 minutes and 11 seconds. Additionally, the clock in the Region Line is showing the current time as 19:42:50. We are pretty sure that this is just a time zone issue. What is the Chart Time Zone set to (Chart >> Chart Settings >> Advanced Settings)? If it is set to the Global Time Zone, then what is the Global Time Zone set to (Global Settings >> Time Zone Settings)? And what Time Zone are you physically in? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-16 20:49:08] |
Thanks John yes I changed the time zone setting from Global to Brussels +1 CET and that solved the issue. Best T.
