Date/Time: Tue, 04 Nov 2025 16:32:26 +0000
Error when compiling in new version of sierra
View Count: 778
[2021-06-15 22:34:37]
aknsyu71@gmail - Posts: 60
Hi Support,
I am getting a CPU exception when compiling my study using 2270
All is fine when compiling in 2256 or earlier versions.
I couldnt find any ACSIL functions that would have been discontinued and the compiler dosnt flag and error either, hope you can help, my guess would be loading unloading DLL's have changed?!
Please see the short screenshot video I made, hope this helps.
Let me know if anything else is required
Andrej
https://drive.google.com/file/d/1cIN_KqKYsNZAhSEEM1Pq6PVq9W509fh8/view?usp=sharing
[2021-06-16 13:44:26]
John - SC Support - Posts: 42755
Are you only having this problem when you compile a study that is already added to the chart? So you are just getting the error after the recompile?
If so, then if you Unload the DLL first and then reload it after the compile are you not having an issue?
We have had another report of the above situation and it is being looked into, but it will be good to know that someone else is having the issue. Please let us know if it is the above, or something else.
[2021-06-16 13:55:59]
Yes that is correct, I only have the issue if the study is loaded on the chart, if I remove the study and then compile it all is fine.
thanks
[2021-06-16 14:49:34]
Thank you for the information. This is being looked into, but it is good to know that there is more than one person with the issue.
[2021-06-16 17:37:19]
There has been an update that appears to have fixed the issue. If you update to the latest Pre-Release you should no longer have the issue.
