Date/Time: Tue, 04 Nov 2025 16:32:27 +0000
Channging Futures symbols in workspace at rollover
View Count: 577
| [2021-06-15 17:21:39] |
| wingz - Posts: 121 |
Is there a way to change the symbol, for all charts within a workspace, without having to do each chart one at a time?
| [2021-06-15 19:58:47] |
| John - SC Support - Posts: 42755 |
The only ability to do something like that would be to have the option for Chart >> Chart Settings >> Automatically Rollover Futures Symbol. But, it is really not recommended as this will automatically change your contract and does not allow you to go back to a previous one (as it will keep rolling over to the current front month contract). Refer to the information here: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-17 15:47:35] |
OK........good to know........thanks for the explanation
