Date/Time: Tue, 04 Nov 2025 16:32:24 +0000
CME micro silver futures (SIL) not available in list of symbols
View Count: 1314
| [2021-06-15 09:06:14] |
| User350416 - Posts: 43 |
Hi The CME micro silver futures (SIL) doesn't display in my list of available contracts (while SI and QI do show up) I have followed the insrtuctions in Global Symbol Settings: Update Symbol Settings but still the symbols does not get available. Can you please help? Thank you |
| [2021-06-15 21:59:21] |
| Sierra_Chart Engineering - Posts: 21306 |
We will add this. Are you using Rithmic?
| [2021-06-16 08:04:40] |
Yes I'm using rithmic Thank you very much. |
| [2021-06-18 07:08:37] |
This is added. However, it is only added for the new Rithmic connection. That will be available we hope later next week. Here is the documentation for it: Rithmic Trading Platform Service Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-18 07:08:50
| [2021-06-18 09:01:47] |
That's great. Thank you very much
