Date/Time: Tue, 04 Nov 2025 16:32:26 +0000
Chart Tabs Hidden On Open
View Count: 649
| [2021-06-14 03:21:22] |
| User462086 - Posts: 196 |
When a chartbook with multiple charts is opened only 1 chart tab is visible. I've noticed this on chartbooks having at least 16 charts. No prior problems with these chartbooks. Selecting another chart from the pull down menu, or selecting another chartbook then the original chartbook, will then show all the chart tabs. Using v2270. |
| [2021-06-14 15:50:14] |
| John - SC Support - Posts: 42755 |
Is this when first opening a chartbook from a previous version (i.e. did you receive this Chartbook from someone else)? Or is it every time opening the Chartbook that has more than 16 charts in it? We just tried to see if we could reproduce this with a new chartbook with more than 16 charts in it, but we are not having any issues with the chart tabs not showing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-15 06:14:08] |
This happens when a couple of chartbooks that I created are opened each day. It didn't happen before upgrading to v2270. I'll do some testing and report back. Date Time Of Last Edit: 2021-06-15 10:41:41
| [2021-06-21 03:11:11] |
Updating to v2276 resolved this, thank you!
