Date/Time: Wed, 26 Feb 2025 21:20:45 +0000
NQ Data and RTY taking extremely long loading times
View Count: 463
[2021-06-04 18:11:52]
Marlin46 - Posts: 34
My Data feed for some of the indexes take an exceptionally long time to upload. Sometimes 3-5 minutes while others generally load in 15-20 seconds. Ideas on how to shorten that time? Also when loaded it stops and freezes up making it almost impossible to trade. Thanks.
Date Time Of Last Edit: 2021-06-04 18:13:49
[2021-06-07 15:58:22]
John - SC Support - Posts: 38218
What exactly is the loading time? Is this the time from when you open the chart until the chart becomes available?
If it is the above, then how much data are you loading for these charts?
[2021-06-07 22:00:21]
This is usually caused by a study:
The problem could be related to this:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.23 - Chart Tick Size and Volume at Price Processing
If the chart tick size is not set correctly, it is going to cause a long load time, and also cause very long study calculation times for certain types of studies.
